Electric field from uniform charge of finite length
The discussion focuses on calculating the electric field generated by a uniform charge of finite length placed along the x-axis. In part (a), the contributor attempts to derive the expression for the electric field contribution from a differential charge segment, using variables such as charge Q, length L, and distance y. There is uncertainty regarding the integration process needed to find the total electric field in part (b), which should be expressed in terms of Q, L, and y. The contributor seeks clarification on the reasoning behind their derived equation and the integration limits. The overall goal is to understand the electric field behavior, particularly as the length of the charge approaches infinity.
Pyuruku
A uniform charge Q of length L is placed on the x-axis with one end at the origin as shown
a) Find the contribution dE (vector) to the electric field at P on the y-axis a distance y from the origin, from the charge at x in dx, in terms of Q, L, dx, ke, x and y
b) Find the total E (vector, in component form) from the whole line of charge at y on the y-axis in terms of Q, L, ke, y; also find E (vector) for |y| >> L
c) Use the result in (b) to obtain the behavior of E (vector, in component form) on the y-axis if L is infinite in the +x direction (left end remains at 0)
I believe this is all I need?
a)
\huge dE = \frac{k\lambda dx}{r^2}<\frac{x}{r},\frac{y}{r}> = \frac{kQdx}{(x^2 + y^2)^{\frac{3}{2}}L}<x, y>
This doesn't look right to me, and I'm a bit stuck on trying to integrate this... I'd assume you integrate with respect to X from 0 to L...
Well let's check it then: what was the reasoning you used to get to that equation?
