Electric field given electric potential
To find the electric field from the given electric potential V = (210 x² - 170 y²) V, the negative gradient of the potential must be calculated. The electric field is a vector quantity represented as E = -∇V, where ∇ is the gradient operator. The partial derivatives with respect to x and y need to be computed to determine the components of the electric field. The solution involves evaluating the derivatives at the specific point (1.00 m, 3.00 m). Understanding the relationship between electric potential and electric field is crucial for solving such problems.
743344
[SOLVED] electric field given electric potential
The electric potential in a region of space is V = ( 210 x^{2} - 170 y^{2} ) V, where x and y are in meters.
What is the strength of the electric field at ( 1.00 m, 3.00 m ) ?
E = -dV/ds
1. i know i have to find the derivative of the that given equation but i can't figure out where to start...because there are two different variable given...and i don't know in term of which variable i have to find the derivative
The E-field is a vector quantity and is given by the negative gradient of the potential.
\mathbf{E} = -\nabla V
the \nabla operator is:
\nabla = \frac{\partial}{\partial x} \mathbf{\hat{i}} + \frac{\partial}{\partial y} \mathbf{\hat{j}} +\frac{\partial}{\partial z} \mathbf{\hat{k}}
thank you
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
