Electric field lines in a cylinder
The discussion revolves around the electric field behavior between two hollow cylindrical conductors, one negatively charged and the other positively charged after being grounded. The relationship between the charges on the two cylinders is questioned, with the conclusion that the electric field inside the blue cylinder is uniform, while the field outside the red cylinder is not. Gauss's Law is applied to derive the electric field, revealing that it depends on the radius, indicating a non-uniform field. The electric field inside the red cylinder is confirmed to be zero, adhering to electromagnetic principles. Participants suggest drawing the field lines based on the cylindrical symmetry, emphasizing that they point radially outward.
jaumzaum
In the figure below we have 2 hollow cylinder conductors. The red conductor has radius R1 and negative charge (Q1). We then introduce the blue conductor (radius R2), first connected to the Earth by a conductor thread. Then we disconnect the thread making the blue conductor charge be positive. The length of the cylinders are L (L>>R).
a) What will be the relation between the charges in the 2 cylinders
b) Calculate the electric field inside the blue cylinder and draw the field lines
Final Configuration:
http://img803.imageshack.us/img803/5536/31756482.png
Actually I haven't seen this problem anywhere, I only need it to understand a MIT experience I saw on youtube. I would say for sure the electric field lines inside the blue conductor will be all parallel each other, so the electric fieldbecomes uniform. But then I apply Gauss Law to the red conductor.
2πRL E = Q1/ε
E = Q1/2πRLε
And E depends on R, so it's not uniform! If it's so, how would be the field lines configuration? And the relations of charges? I'm pretty stuck in this.
Any help will be appreciated.
Thanks
John
The field cannot be uniform. It has to have a cylindrical symmetry: all field lines point in radial direction.
You mean in the cylinder axe? So the electric field in the center would be none? Why is that?
And how can I calculate the e field in function of the height h?
No.
The electric field in the interior of the red cylinder? That is zero. Everything else would violate the laws of electromagnetism.
It does not depend on the height. Do you mean r? With Gauß law, as you did.
I thought by radial you mean in the axe direction. So I'm right, E = Q1/2πRLε.
How can I draw the lines?
Draw a disk as part of the cylinder, and find the direction of the electric field there. It is the easiest possible field.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
