Electric field of a charged ring.
The discussion focuses on calculating the electric field (E) at point P, located at z=4.00 cm, due to a uniformly charged ring with charge Q=6.10 microCoulombs and radius R=1.30 cm. The derived formula for the electric field in the z-direction is E_z = (kQx) / (x^2 + R^2)^(3/2), where k is the Coulomb's constant. The integration limits for the charge element dq were established as 0 to 2π, allowing for the complete evaluation of the electric field contribution from the entire ring.
  • Understanding of electric fields and Coulomb's law
  • Familiarity with integration techniques in calculus
  • Knowledge of linear charge density and its calculation
  • Basic concepts of symmetry in electric field calculations
  • Study the derivation of electric fields from different charge distributions
  • Learn about the application of Gauss's Law in electrostatics
  • Explore the concept of electric potential and its relation to electric fields
  • Investigate numerical methods for solving electric field problems in complex geometries
Students and professionals in physics, electrical engineering, and anyone involved in the study of electrostatics and electric field calculations.
NeverSummer
bionut said:
As part of the optics in a prototype scanning electron microscope, you have a uniform circular ring of charge Q=6.10 microCoulombs and radius R=1.30 cm located in the x-y plane, centered on the origin as shown in the figure.
What is the magnitude of the electric field, E at point P located at z=4.00 cm ?
E=kQ/(r^2)
dE=kdQ/(r^2)=kdQ/(sqrt(h^2+r^2))=∫(k/4.206)dQ
=2.14*10^9 Q
Now, I'm not sure I've made it thus far correctly, so if I've gone wrong, please let me know. Either way, I have no idea what my limits of integration would be for this, so I'm pretty much stuck here.
I kind of follow your work, but I'm afraid I don't see the complete equation needed, so I will go ahead and derive it for you.
Alrighty, here's a little picture to help us out.
Let's keep this in mind throughout the whole problem.
We know by symmetry that the electric field due to the ring at point P is going to be straight up in the Z direction. In the picture, I have the electric field element \begin{equation} dE \end{equation} due to a charge element \begin{equation} dq \end{equation}.
Let us define that charge element. Because we have a ring, it will have a linear charge density (charge per unit length), \lambda = Q/l = Q/2\pi R, where L (lower case in the equation) is the circumference of the ring, it's length. Let's look at another picture for substitution reasons:
This picture shows us that \begin{equation} dl=Rd\theta \end{equation}.
So now we can say (using the equations above) \begin{equation} dq=\lambda dl = \frac{Q}{2\pi R} Rd\theta = \frac{Q}{2\pi} d\theta \end{equation}
Let's not forget any of this as we move on!We know from the equation of an electric field that \begin{equation} dE = k \frac{dq}{r^2} \end{equation}. Where \begin{equation} r=\sqrt{R^2+x^2}\end{equation} - from the first picture.
Like said before, we know that the electric field is going to be vertically up in the Z direction, so we want to find the electric field straight up (dE_z) due to our charge element, we can use trig from our first picture to say this: dE_z = dE \cos{\theta}
And we know from our first picture again that \cos{\theta} = R/r
Now let's do some substitution using A LOT of what we have done before:
dE_z = dE\cos{\theta}
dE_z = k \frac{dq}{r^2} \frac{x}{r}
dE_z = k \frac{Q/(2\pi)}{x^2+R^2} \frac{x}{\sqrt{x^2+R^2}} d\theta
\int dE_z = \frac{k}{2\pi} \frac{Qx}{(x^2+R^2)^{3/2}} \int_{0}^{2\pi} d\theta <-- integrating from 0 to 2pi (the whole ring) = 2*pi
And now we have our solution:
E_z = \frac{kQx}{(x^2+R^2)^{3/2}}
Now all you do is plug your numbers in
By the way this is not the only way to reach this solution, just the way I was taught. If you google "electric field due to a ring of charge" - you may find some other ways
Thanks for the great explanation, I got it!
  • · Replies 16 ·
