Electric field of a line of charge
The discussion focuses on calculating the electric field at point P due to a finite line charge with a linear charge density (λ) of +3 μC/m and a total length (L) of 5 m, positioned 4 m away (s). The electric field components in the x-direction and y-direction are derived using the equations E_x = ∫(kλ/r²)cosθ dy and E_y = -∫(kλ/r²)sinθ dy, respectively. The correct numerical results for the x-direction yield approximately 5270.86 N/C, while the y-direction calculation is disputed, with participants clarifying the integration limits and the correct expressions for r and trigonometric functions.
  • Understanding of electric fields and line charges
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of trigonometric functions and their application in physics
  • Basic concepts of electrostatics, including Coulomb's law
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the application of integration in physics problems
  • Explore the use of trigonometric identities in vector components
  • Review examples of calculating electric fields for different charge configurations
Students studying electromagnetism, physics educators, and anyone involved in solving electrostatic problems related to line charges.
andylie
The figure below shows a finite line charge with linear charge density of λ and total length L. The point P shown is a distance s away from its end.
Please calculate a formula for the electric field at point P, in terms of λ, L and s.
Then use the following values to find it numerically.
λ = +3 μC/m, L = 5 m, s = 4 m
Electric field to point P in the x direction is going to be dE*cosΘ y direction is going to be -dE*sinΘ
the equation for is E=∫(k*λdy/r^2) , where λ=Q/L, r=(s^2+L^2)^(1/2)
limit of integral is from 0 to 5
i did get the answer for +x direction, but i couldn't get the answer for -y direction
for the x-dir, my eq start from ∫(Kλdy/r^2)cosθ. where cos=s/r
so it become ∫(kλdy/r^2)(s/r) since, k,λ,s, is a constant, the integration become
kλs∫dy/(s^2+y^2)^(3/2) using table of integration for ∫dy/(s^2+L^2)^(3/2), then
kλs(1/s^2)(y/(y^2+s^2)^(1/2)) s on the numerator and denominator cancels each other
(kλ/s)(5/(5^2+4^2)^(1/2))
((9*E9)(3*E-6)(5)/4)*(5/(5^2+4^2)^(1/2))=5270.8644
for the y-dir, its negative.
limit of integration is 0 to 5 of L value
my eq start from ∫(Kλdy/r^2)sinθ. where sin=L/r
so it become -∫(kλdy/r^2)(L/r) since, k,λ,L, is a constant, the integration become
-kλL∫dy/(s^2+y^2)^(3/2) using table of integration for ∫dy/(s^2+L^2)^(3/2), then
-kλL(1/s^2)(y/(y^2+s^2)^(1/2)
-(kλL)(5/(5^2+4^2)^(1/2))
-((9*e9)(3*E-6)(5)/(4^2))*(5/(5^2+4^2)^(1/2))= -6588.58058
but for the y-dir value is wrong. can someone help me?
Is it ok if I can't make out head or tails from your story ? And the sheet from your notebook also is somewhat difficult to follow. So I propose we pick up what is understandable and take it from there.
I agree with ##E_x=\int_0^L \frac{ k \lambda}{r^2} \cos\theta\ dy ## but not with ##r^2=s^2+L^2##. Also not with considering ##\cos\theta = s/r## as a constant.
For the distance you have ##r^2=y^2+s^2## and ##\cos\theta = s/r(y)##.
In your notes
  • the ##1/r^2## is missing in the first line
  • the integral sign is missing in the second line
  • the third line and onwards look ok provided one reads y instead of L in the proper places
You should not be needing a table of integration to do the integral, but ok. I get 5270 too. Can't decipher the units. Should be N/C.
On with the y component. I vaguely distinguish a minus sign. This time you need a sine and you grab L/r. Nice try, but that's only at the end when y = L .
again, ##r^2=y^2+s^2## and now ##\sin\theta = y/r(y)##.
This enough to get you going again ?
I already turned it my assignment, i didnt get that one correct, but thank you though.
:D
  • · Replies 18 ·
