Electric Field of a Uniformly Charged Ring
To find the electric field on the axis of a uniformly charged ring, the total charge and distance from the center must be accurately applied in the equations for electric force and field. The problem involves a ring with a radius of 8.1 cm and a charge of 118 micro Coulombs, with the electric field calculated at a point 1.15 cm from the center. There is confusion regarding the correct distance to use in the calculations, specifically whether to subtract the axial distance from the radius or apply the Pythagorean theorem. Clarification is needed on the interpretation of "axis" in the context of the problem. Accurate calculations will yield the electric field in units of N/C.
ILoveCollege
A uniformly charged ring of radius 8.1 cm has a total charge of 118 micro Coulombs. The value of the Coulomb constant is 8.98755e9 N M^2/C^2. Find the magnitude of the electric field on the axis of the ring at 1.15 cm from the center of the ring. Answer in units of N/C.
F= k Qq/ r^2
E= kq/r^2
I tried subtracting 1.15 cm from 8.1 cm for "r" and plugged that "r" value in the F equation but that answer is wrong. By axis , do they mean horizontally (as in along the diameter) or vertically?
do i just do the pyth. theorem to solve for "r" ( square root of 8.1^2 + 1.15^2)?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
