How Does Relative Permittivity Relate to the Electric Field in Capacitors?
The discussion focuses on the relationship between relative permittivity (εr) and the electric field in capacitors. The equation for the electric field (E) is presented, highlighting that ε equals εr multiplied by ε0, where ε0 is the permittivity of vacuum. The introduction of a dielectric medium between capacitor plates reduces the electric field due to polarization, which in turn increases capacitance. The ratio of capacitance with and without the medium defines relative permittivity. Understanding these concepts is crucial for grasping how materials affect electric fields in capacitors.
jeff1evesque
An electric field of a capacitor is defined by the following equation,
\vec{E} = \frac{\rho_{s} \hat{a_n}}{\epsilon} = \frac{Q\hat{a_n}}{A\epsilon_r\epsilon_0}
where \vec{E} = (\frac{\rho_s}{\epsilon})\hat{a_n}
Question
I understand the first equality, and reviewing my physics book, I think I understand the derivation. But I was wondering if \epsilon = \epsilon_r\epsilon_0, and a quick explanation why.
Thanks,
JL
Question
Thanks,
JL
Here εο is the permittivity of the vacuum and εr is the relative permittivity of the medium which is introduces between the plates. It is also called as the dielectric constant.
Actually, do you mind explaining why it was necessary to break the permittivity into those components? And why the product is equivalent to the permittivity?
Thanks again,
JL
Permittivity ε is the property of the space. If you introduce anything between the plates of the capacity, the electric field will decrease due to polarization.. Consequently the potential difference between the plates will decrease and hence the capacitance will increase.
The ratio of capacity with medium and capacity without medium is called relative permittivity εr. εr = Cm / Co = (εA/d)/(εoA/d) = ε/εr
