Electric field on a point charge
To find the electric field produced by the nuclear charges in an H2O molecule at point P, it is essential to first accurately visualize the arrangement of the nuclei and point P. The law of cosines can help determine the distances involved, but a sketch is crucial for understanding the vector directions of the electric fields. Each electric field vector will point away from the respective nucleus, and the magnitudes can be calculated using the formula involving charge and distance squared. After calculating the components of the electric field vectors in both x and y directions, they should be summed to find the total electric field at point P. Proper visualization and component analysis are key to solving this problem effectively.
skidkid
The distance between the oxygen nucleus and each of the oxygen nuclei in an H2O molecule is 9.58*10^-11m; the angle between the H atoms is 105 degrees. Find the electric field produced by the nuclear charges (positive charges) at the point P at a distance of 1.20*10^-10m to the right of the oxygen nucleus.
The law of cosines.
I used the law of cosines to find the distance from the oxygen atom to the point P, but I don't know where to go from there.
skidkid said:
The distance between the oxygen nucleus and each of the HYDROGEN nuclei in an H2O molecule is 9.58*10^-11m; the angle between the H atoms is 105 degrees. Find the electric field produced by the nuclear charges (positive charges) at the point P at a distance of 1.20*10^-10m to the right of the oxygen nucleus.
The law of cosines.
Hi,
You have a mistake in your statement of the problem on the first line. I corrected it above for you. Here's the deal: you need to draw a picture of the situation first. Don't worry about equations until you have sketched your three nuclei and placed your point. Then at the point draw in a little vector arrow representing the electric field due to each charge. Hint: the vector for a given nucleus will point away from that nucleus. Now you are going to have to figure out the magnitude of that vector at the point. There's this nice equation that's got a q in the numerator and an r-squared in the denominator (also a constant out front) that gives you the magnitude of the electric field. Your job then is to figure out the components of each of the electric field vectors in the x and y directions and add them up (x components with x components and y components with y components). So you see the law of cosines is only part of it. I haven't see your drawing so I'm not sure where P is, but I'll bet that if you draw your picture with the x and y axes in the right place you can save yourself some work.
Hope this gets you started!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
