Electric Field Question: Finding Zero Point Between Two Charges on Y-Axis
Two point charges, q1 = -9 μC at y = 6.0 m and q2 = -8.0 μC at y = -4.0 m, are analyzed to find the point along the y-axis where the electric field is zero. The initial equations set up to find this point contained a typo, which was corrected to reflect the correct distances from the charges. The discussion highlights the need to simplify the equations correctly, particularly by taking square roots and ensuring positive values. A suggestion was made to multiply both sides of the equation by (r + 4) to solve for r, which helped overcome a mental block in the problem-solving process. The conversation emphasizes the importance of careful setup and algebraic manipulation in solving electric field problems.
thebigbluedeamon
I need a little guidance in this problem...
Two point charges lie along the y-axis. A charge of q1=-9 mu*C is at y=6.0m, and a charge of q2=-8.0 mu*C is at y=-4.0 m. Locate the point (other than infinity) at which the total electric field is zero.
So,
I made the statement
E1y = -E2y
and
Ke (q1/(r-4)^2) = Ke (q2/(r+4)^2)
or
q1/(r-6)^2 = q2/(r+4)^2
But that makes it very hard to solve for r. Is that equation set up correctly? If so, what is the easiest way, algebraicly, to solve for r.
or
I think you have a typo in the equation above. Take the square root of both sides and simplify.
I did have a typo...It was supposed to be a 6 instead of a 4 in the first equation.
Let me try this and hopefully I can solve.
Okay...so I took the square root of both sides of the equation, but that doesn't seem to get me very far.
I end up with:
sqrt(q1/q2) = (r-6)/(r-4)
And frankly I don't know how to solve for r in this situation. I could use Maple or something, but it seems that this problem shouldn't require that. I think I might have got the initial set up wrong.
Two problems: (1) another typo, and (2) when you take square roots you better be sure your answer is positive.
Your equation should be: sqrt(q1/q2) = (6-r)/(r+4)
Start by multiplying both sides by (r+4). It's a simple linear equation.
Of course it is. I just had a mental block. I wouldn't have caught the "(6-r)" though. Thanks for your help.
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
