How Do Electric Fields Affect Particle Movement?
The discussion revolves around calculating the electric field's magnitude and direction at a specified point in a diagram involving two charges. Additionally, it addresses the speed of an electron released from rest in a parallel plate apparatus with a 500 V potential difference. The user initially seeks help with these physics problems but later confirms they found the solution to the first question. The conversation highlights the challenges of recalling relevant equations and concepts related to electric fields and particle movement. Overall, understanding electric fields is crucial for predicting particle behavior in electric fields.
Tariq
1. What is the magnitude and direction of the electric field at point Z in the diagram?
q = - 2.0 x 10-5 C q = + 8.0 x 10-6 C
60 cm 30 cm
X Y Z
2. An electron is released from rest adjacent to the negative plate in a parallel plate apparatus. A potential difference of 500 V is maintained between the plates, and they are in a vacuum. With what speed does the electron collide with the positive plate?
Electric Field type questions
I attempted them but I don't remember how to do them, it was a long time. I need some assistance. Your help will be greatly appreciated. Thank you.
nvm I got the answer for the first one though.
