Electric field required to keep electron at rest
The problem involves determining the electric field required to keep an electron at rest while it travels through a magnetic field. The context is rooted in electromagnetism, specifically the interactions between electric and magnetic fields as described by the Lorentz force law.
  • The original poster attempts to equate the forces acting on the electron and derives an expression for the electric field based on the cross product of velocity and magnetic field. Some participants question the correctness of the derived components of the electric field and explore the conditions for perpendicularity between the electric and magnetic fields.
Participants have engaged in verifying the derived expressions and discussing the conditions for perpendicularity. There appears to be a productive exchange regarding the mathematical relationships involved, with some participants affirming the correctness of the original poster's calculations.
There is an implicit assumption that the electron's velocity remains constant and that the forces involved are balanced. The discussion also reflects a need for clarity on vector relationships and properties in the context of the problem.
boiteporte
An electron is traveling through a magnetic field B=(Bx, By, Bz). Find an expressions for the electric field E required to keep the electron's velocity constant at v=(0,vy,0). Hence, show that E and B are perpendicular.
F=q(v cross B)
F=qE
Ok, I totally messed up this question. That's for sure. First, I decided to set the two forces equal to each other using q=-e since it is an electron. So, -e(v cross B)=eE (There are no minus signs on the right hand side, since it is going in the opposite direction).
So, E= -(v cross B). Then I had absolutely no idea what to do so the rest is probably wrong but, that's what I did (I decided to split it up in the 3 components) :
For the x-component, I got Ex=-(-vy*Bz)=vy*Bz
For the y-component, I got Ey=0
For the z-component, I got Ez=-(vyBx)=-vyBx
So, putting them altogether gives E=(vyBz,0,-vyBx). I don't think this answer is right though...
For the second part of the question, I said that the force is perpendicular to the magnetic field (as shown by the Lorentz Force equation) and since the force is parallel to the electric field, then the electric field is perpendicular to the magnetic field. I know there is a way to show it using Maxwell's Equation but the way the question is written implies that I have to use my previous answer. But I'd like some help please...
There is no mistake in your derivation.
For the second part, how could you check that two vectors are perpendicular?
Two vectors are perpendicular if their dot products equals 0. But, I still don't see where this is going...
Sorry for my previous reply. I understand now. I have E=(vyBz,0,-vyBx) and B=(Bx,By,Bz). So, their dot products is vyBzBx+0-vyBxBz=0. So, they are perpendicular. Is this correct now?
Yes, it is all correct. Well done!
  • · Replies 17 ·
  • · Replies 0 ·
