Electric Field Strength at Center of Triangle
The discussion focuses on calculating the electric field strength at the center of an equilateral triangle formed by three positive charges. The charges are 3 × 10-6, 2 × 10-6, and 3 × 10-6 Coulombs, positioned at the triangle's corners with a side length of 0.2 meters. The user initially struggles with determining the correct center of the triangle and calculating the distances from each charge to this center. After several attempts, they identify a geometric error in their calculations, which was causing discrepancies in their results. Ultimately, the user resolves the issue by correctly identifying the triangle's center, leading to accurate calculations.
rbrayana123
Three positive charges, A, B and C, of 3 × 10-6, 2 × 10-6, and 3 × 10-6 Coulombs respectively, are located at the corners of an equilateral triangle of side 0.2 meters.
Find the magnitude in Newtons/Coulomb of the electric field at the center of the triangle.
E = \frac{1}{4∏ε} Ʃqjroj/roj2
I'm not quite sure what I'm doing wrong but I feel like it's something simple (and perhaps geometric). My triangle has a base on the x-axis and it's origin is at the center of the base. My basic approach is to find the center of the triangle.
Then, I compute the distance from each point charge to the center via Pythagorean.
Once I have that, I compute the electric field strength for each particle. Then, I take the x and y components and add them.
I've tried different centers for the triangle but I'm always off by a factor of 10.
Hey, just wanted to say that I figured it out. As I suspected, it was a geometric mistake when calculating the center of the triangle. Looks like I need to go over some middle school math =/
