Electric Fields using Gauss' law
The discussion centers on applying Gauss' law to find electric fields inside and outside a charged slab. The participants clarify that the electric field is constant on the surface of a Gaussian surface and that the charge distribution is symmetric, which simplifies calculations. For the inside of the slab, the limits of integration are based on the height of the Gaussian surface, while for the outside, the entire charge of the slab is considered. The final equations for the electric field are derived, showing that inside the slab, E is proportional to z², while outside, E is constant. The key takeaway is the importance of correctly defining limits of integration and understanding the symmetry of the charge distribution.
ParoXsitiC
http://i.minus.com/jbxXiQZmmiOQtS.png
Elecric flux = Integral of closed surface of E dotted into dA = qenclosed / ε0
Rho = 50 x 10^-6 abs(z)
Integral of closed surface of E dotted into dA will end up being EA when E is constant.
as such,
EA =qenclosed / ε0I believe I have to use the function of the Rho in the integral
qenclosed = Intergal Rho * dV
As given we know to find dV we use the area (A) multiplied by dz.
Such as that
A * 50 x 10^-6 * Integral abs(z) dz
It here I believe that defining the limits tells us rather we are taking from within inside or outside. In my notes we are using a cylinder bar and Gaussian surface of a ring and going from 0 to R (R radius being that of cylinder bar) for inside and 0 to r (r being distance from center of cylinder bar to ring).
I have no idea what to put for my limits to get the inside and outside.
Moderator note: Moved to the introductory physics forum.[/color]
gauss's law basically says that net flux through a surface is proportional to the enclosed charge.
gauss's law is for symmetrical charge configurations (i.e. you want the electric field to be constant across the Gaussian surface.
now your charge distribution is symmetric on the xy plane (z=0).
when z=0, you have an equal amount of charge above and below you, so E=0
if you took a really small box, centered at the origin, and increased it height (z direction), the total enclosed charge would be the integral of rho, over the area of this box. your limits of integration are the bottom and top of this box (hence dV = A*change in height(dz).
as you integrate inside the slab, more of the q is enclosed so your electric field gets stronger, once you gaussian box is outside the slab, no additional charge is inclosed so your limits of integration for Qenc is just the thickness of the slab
That is what I originally thought, given L = 0.20m I would do:
Limits from -L/2 to L/2 , or in other words -0.10m to 0.10m. Taking into consideration I am integrating the absolute value of z dz I am left with L * |L| / 4 or 0.01.
So,
EA = (50 x 10 ^-6)(A)(0.01)/enought
E = (50 x 10 ^-6)(0.01)/enought
However, this no longer gives me a "function of z" so I am getting confused here. Also how would the equations differ from inside and outside the slab? I think my issue is that I didn't make a Gaussian surface so I have no "r", that is a measurement from the origin to the distance "r" to the Gaussian surface.
∫E.da = μ_{o}∫ρdv
the value of E at points located on the surface equals
the integration of ρ (charge/unit volume) over any
charge distribution that is inclosed by the surface where we are finding E
so when we find E inside the slab, the gaussian box extends to a point z (-a/2<z<a/2)
and the integration of ρ extends to the surface of this box.
you integrate both integrals to plus / minus z, and this gives you E as a function of z
So you are saying it should be:
{50}*10^{-6} * A * \int\limits_{-z}^{z} |z| \, \mathrm{d} z.
But that integral doesn't evaluate correctly
Upon looking at the picture again I realize the slab is not location in the middle but starting at 0.
I know that the outside electric field would encompass all charges enclosed and thus would be:
EA = \frac {50 * 10 ^{-6} * A *\int_{0}^{0.20} |z| dz}{ε0}
EA = \frac {50 * 10 ^{-6} * A * (0.02) }{ε0}
EA = \frac {1* 10 ^{-6} * A}{ε0}
E = \frac {1* 10 ^{-6}}{ε0}
So how would I do this for the inside? Would I just makeup a variable and have it be between 0 and 0.20? let's use the variable r (for radius) as I am use to cylinder problems of this nature (where r vs R, but in this case r vs 0.20)
Would it then be
EA = \frac {50 * 10 ^{-6} * A *\int_{0}^{r} |z| dz}{ε0}
the graph of rho vs z makes it seem the slab is centered at the origin. regardless, you want the middle of your gaussian surface to be aigned with the middle of the slab. this way, as the height of the box is increased equal amounts in +/_ z direction, there is an equal amount of charge in the upper and lower halves of the box, allowing the vaue of E to be constant at the surface of the box.
for inside the slab, the E . da is zero on the walls of the box, and equals magn. of E on the top and bottom surface.
Ienc = integral of rho from (middle of slab - z) to (middle of slab +z)
after integrating,
E*(area integral) = enclosed charge as a function of the height(z) of the gaussian surface.
when you evaluate the enclosed charge integral, your limits are a func of z, so your evaluated integral will be a function of z
"In my notes we are using a cylinder bar and Gaussian surface of a ring and going from 0 to R (R radius being that of cylinder bar) for inside and 0 to r (r being distance from center of cylinder bar to ring)."
so i think you ment your gaussian surface was a pipe, or the surface of a cylinder.
here you go from 0 to r b/c the charge distribution is cylindrically symetric, i.e. you use cylindrical coordinates.
for the slab, the is no cylindrical symmetry, rather "planar" symmetry or whatever you want to call it. In this case, it is more convenient to use cartesian coordinates.
likewise, if the charge dist. was a sphere, your gauss surface is also a sphere and you use shpereical coordinates.
**the whole point is that the strength of the electric field is constant on the surface of your gauusian surface
After speaking to the professor the answer turns out to be:
Outside:
E * A = \frac{50 μC * A * 2\int_{0}^{0.10} z dz}{ε0}
E = \frac{50 μC * 0.01}{ε0}
E = \frac{0.5 μC}{ε0}
Inside:
E * A = \frac{50 μC * A * 2\int_{0}^{z} z dz}{ε0}
E * A = \frac{50 μC * A * 2 \frac{z^2}{2}}{ε0}
E = \frac{50 μC * z^2}{ε0}
It was the trick of getting of of the absolute value by just doing 2\int_{0}^{z} z dz instead of \int_{-0.10}^{z} |z| dz, The z being 0.10 when outside
As thought, she was using a variable (z) to symbolize any value between 0 and 0.10. Using z as one of the limits in \int_{0}^{z} z dz threw me off as my ti-89 said it was an incorrect integral.
