Electric flux through a plane described by an equation
To find the electric flux through the surface defined by the equation x = 6y, the electric field components are given as Ex = 6.0 N/C and Ey = 7.0 N/C. The initial calculation for flux yields 36 Nm²/C, which matches the textbook answer, but there is uncertainty regarding the inclusion of the angle between the electric field and the surface normal. The discussion emphasizes the need to determine the angle between the electric field lines and the normal vector to the surface area for accurate flux calculation. Clarification is sought on how to derive this angle relative to the defined plane. Understanding the relationship between the electric field and the surface normal is crucial for correctly applying the flux equation.
turquoisetea
The elctric field in a certain region of space has components Ex = 6.0 N/C, Ey = 7.0 N/C, and Ez = 0. Find the electric flux though the surface x = 6y, 0 < x < 6.0 m, 0 < z < 1.0 m. What is the angle between the electric field and the unit vector normal to the surface?
Flux=E dot A
Flux=(6N/C)(6m)(1m)= 36 Nm^2/C
This is the same as the answer in the back of the book but it seems too easy, and I think there should be a cosine in there.
You have \vec{E}(x, y, z)=(6.0, 7.0, 0) N/C.
\Phi=\vec{E}(x, y, z)\bullet\vec{S} where \vec{S} is a vector area. You can use the magnitudes of the vectors and the angle between them as EScos\phi, where \phi is the angle between the field lines and the normal to the the surface area S. Do you know how to find the normal to the surface you have?
Yes, I understand where the normal is, I just don't understand how to find the angle between the E-field lines and the area vector (normal). I can find the angle between the e-field lines and the x and y-axis but I cannot find the angle of the plane.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
