How Is the Number of Electric Field Lines Calculated in Gauss' Law?
In summary: In the Gauss' law, using the formula q/epsilon, you can calculate the total number of lines of force that are coming out of the charge.The electric field E however is measured so that we can use it in the Lorentz force equation, F = qE, so E is measured in Newtons per coulomb (N/C).To convert one to the other, we define (in the absence of polarisation) D = εE, where ε is the permittivity of the medium (in anisotropic media, ε is a tensor so the two fields needn't be parallel).
ananthu
106
The electric flux around a charge is represented by electric lines of force. But it is said that the electric lines of force is purely an imaginary concept to visualize a field. In the Gauss' law, using the formula q/epsilon we calculate the total number of lines of force. For a charge of 1 coulomb, it works around 1.129x10^11 in free space. How do you explain this exact number they arrive at?
Is this number is a real one and if it is so, then how is it possible to count the number of some thing which itself is just an imaginary way of visualizing an abstract idea? Does it mean that actually so many number of lines are emerging from a point charge like fine hairs sticking out of a sphere in space?
ananthu said:
… In the Gauss' law, using the formula q/epsilon we calculate the total number of lines of force. For a charge of 1 coulomb, it works around 1.129x10^11 in free space. How do you explain this exact number they arrive at?
It makes a lot more sense if you look at the flux of the displacement D field, rather than the E field …
the electric displacement field D has lines of force coming perpendicularly out of a conductor, and (in equilibrium, where all the charge is on the surface) the number of lines equals the surface charge density: D = σ.
So D is measured in coulombs per square metre (C/m2).
In vacuum, ε = ε0, the permittivity of the vacuum.
It equals 1/µ0c2 where c is the speed of light and µ0 is the permeability of the vacuum.
µ0 is defined as 4π 10-7 henrys per metre (H/m), and µ0c2 happens to be around 1.129 1011 henry metres per second squared (Hm/s2), so ε0 is around 8.85 10-12 farads per metre (F/m).
(a henry times a farad equals a second squared: HF = s2)
(C/m2 per N/C = C2/Nm per m = C2/J per m = F/m)
If it wasn't for that arbitrary 10-7 in the definition of µ0, then ε0 would simply be 1/4πc2 (in farads per metre). :wink:
For the D field, the number of lines is the surface charge density, so it's as if there's one line sticking out of each charge.
hmm lines o force
I think there is no such thing as "lines" of force in either magnetism or electrostatics
Iron fillings will line up in what seems to be lines but that does not prove the lines exist.
thanks for all the reply.
Regarding. tiny-tim's reply, the explanation is too technical to explain to a class of higher secondary school students.
When I say that there are millions of sand grains present in the handful of sand I hold, it is o.k.
No body will question us. But if I say, there are 15 lakh, 28 thousand and 233 sand grains in my hand, then I should justify the number I assert.
There is another difference in the above comparison also. At least, in the case of sand example. there is some possibility of counting them as they are visible.
hi ananthu! :smile:
what's technical about …
… ?? :confused:
The "number" you get is actually not just a number, and it doesn't count anything. It's a value with units,
[tex]\frac{1\ \mathrm{C}}{\epsilon_0} = 1.129\times 10^{11}\ \mathrm{Vm}[/tex]
(that's volt-meters). It represents the total amount of electric flux coming out of the charge.
Whenever you draw electric field lines, you have to choose an amount of flux for each line to represent. For example, you might choose to have one line per [itex]1.41\times 10^{10}\ \mathrm{Vm}[/itex] of flux, and in that case there will be 8 lines coming out of a 1-coulomb charge. Of course, usually you just pick a number of lines to draw and don't worry about exactly how much flux each one represents, but still, that choice is implicitly being made.
1. What is electric flux force?
Electric flux force is a measure of the strength and direction of an electric field. It represents the amount of electric field passing through a given area perpendicularly.
2. How are electric flux force lines created?
Electric flux force lines are created by drawing lines in an electric field that represent the direction and strength of the electric field at different points. They always start at positive charges and end at negative charges.
3. What do the electric flux force lines tell us about an electric field?
The electric flux force lines give us information about the direction and strength of the electric field. The closer the lines are together, the stronger the electric field is at that point. The direction of the lines shows the direction of the electric field.
4. How is the strength of an electric field related to the number of electric flux force lines?
The number of electric flux force lines is directly proportional to the strength of the electric field. The more lines there are, the stronger the electric field is at that point. Conversely, the fewer lines there are, the weaker the electric field is.
5. Can electric flux force lines intersect?
No, electric flux force lines cannot intersect. This is because they represent the direction of the electric field, and if they were to intersect, it would mean that the electric field is pointing in two different directions at the same point, which is not possible.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
