Electrical networks(linear algebra)
To determine the currents in electrical networks when they are not labeled, one can assign currents in any direction, labeling them distinctly if they differ. The principles of Kirchhoff's laws are essential, as they state that current is conserved at junctions and that voltage differences drive current flow. Voltage plays a crucial role in producing current, similar to how gravity influences water flow. When analyzing a circuit, it's important to recognize that the total current entering a junction must equal the total current leaving it. If the assumed direction of a current is incorrect, the resulting negative value indicates the actual flow direction.
EV33
1. Homework Statement
Determine the currents in the various branches.
Then there is a picture of the network which has batteries, resistors, and nodes.
Most of the problems have the currents labeled.
My question is when the currents are not labled how do you determine where to put them and what direction to give them?
2. Homework Equations
No equations.
3. The Attempt at a Solution
By looking at the the various electrical networks in the book it looks like you can put the currents anywhere and in any diretion.
No equations.
Have you learned what role voltage plays in "producing" current? Are there any numbers indicating voltage or potential difference? And by networks, are you referring to circuits?
To solve these problems he has us using Kirchhoff's first and second law.
We get the amount of ohms at each resistor, the amount of volts at each battery and like I said typically it will show us the currents direction.
I haven't truly been taught what voltage does in producing current but those are the two laws the book gives.
We didn't get much of an explanation of these problems in general but the explanation we got very much so lacked the concepts involved because it is for my linear algebra class rather than for a physics class.
The book calls them networks but yes they are cicuits.
Well basically without seeing a diagram the idea is that current cannot be created or destroyed, so when a wire is split, the amount of current in each of the splits must be equal to the amount of current that came into the split... like a river forking.
When two or more wires join, its like rivers merging, the amount of current entering from each tributary must equal the total current in the large part of the river.
Voltage differences drive current like gravity drives the flow of water in a river.
If one then looks at the circuit as a whole and picks a particular spot in that circuit and then moves around the circuit all the way back to the spot, the voltage (or energy per coloumb of charge must be the same. So on your trip around the circuti you might "gain" or "lose" energy along the way, but by the time you have completed your route you must have the same energy per coloumb of charge. One usually "gains" electrical potential energy at batteries and "loses" electrical potential energy at resistors...
This is the simplified basics behind Kirchoffs stuff. Sorry for the delay in response, I went and got a hamburger.
You give a current a distinct label if it's different from the other currents in the circuit, and you can choose whatever direction you want. When you work out the problem, if you guessed the wrong direction, the current comes out negative, but the magnitude is correct.
