Electricity and magnetism point charges problem
The discussion revolves around a problem involving four point charges, three positive and one negative, arranged linearly with equal distances between them. Participants express confusion over the lack of numerical values in the problem statement. It is clarified that the charges can be represented as +q for the three positive charges and -q for the negative charge. The solution involves applying Coulomb's law to calculate the forces between the charges and then summing these forces vectorially to determine the net forces on each charge. The goal is to find the ratio of the largest to the smallest net force acting on the charges.
ravsau
Four point charges have equal magnitudes. three are positive and one is negative, as the diagram shows. they are fixed in place on the same straight line, and adjacent charges are equally separated by a distance d. consider the net electrostatic force acting on each charge. calculate the ratio of the largest to the smallest net force.
(+) ------- d --------- (+) ------- d --------- (+) -------- d --------- (-)
A B C D
This questions has no numbers so I am confused
A B C D
You don't need numbers. Let the first three charges be +q and the fourth -q. What is the force of B on A? (hint: Coulomb's law).
Once you work that out, calculate the forces of C on A and of D on A and add them all up vectorily. Then work out the forces on B, C and D.
AM
  • · Replies 68 ·
