Electromagnetics coulombs law and field intensity
The discussion revolves around calculating the electric field (E) at point P(0,0,h) above a circular region with a uniform surface charge density (ρs). The initial attempt used the formula for the electric field of an infinite sheet, which was deemed incorrect for this scenario. Participants suggested that the expression for the electric field along the axis of a ring of charge might be necessary, but the original poster lacked this information. The conversation highlights the confusion over applying the provided equations effectively to solve the problem. Clarification on the correct approach to find E in this specific context is needed.
Alwaysprolol
The circular region, ρ < a, z= 0, carries a uniform surface charge density ρ ( subscript s). Find E at P(0,0,h), h > 0.
Coulombs law
Field of a line charge and field of a sheet charge.
I'm not sure what they are asking for , but my attempt I used the equation for a field of a sheet of charge cause it's the only one provided in the Homework that contains the ρ (subscript s).
It says E at point (0,0,h) so I'm guessing since its at z = 0 then the vector would be (0,0,h-0). Resulting in my result of
E = (ρ(subscript s) / 2ε ) (0,0,h)
Im not really sure what I'm supposed to be finding
Okay so I get a little bit, I'm looking for the E of a circular region with the radius of ρ ?
Coulombs law
I'm not really sure what I'm supposed to be finding
Hello Alwaysprolol. Welcome to PF !
(Use the X2 and X2 icons for superscripts & subscripts.)
Using the E field for an infinite sheet gives the wrong answer.
Do you have an expression for the E field along the axis of a ring of charge?
Thanks!
Unfortunately, I was not given one. The professor has given us only equations for E of a line charge and a sheet and I'm not quite sure how to utilize them in this question since its asking for the E in a circular region
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
