Electromagnetism - Cross Product of length and Magnetic Field
The problem involves a stiff wire bent at a right angle, with one section along the z-axis and another along the line y=2x in the xy-plane. A current flows through the wire while it passes through a uniform magnetic field, prompting a discussion on the forces acting on the wire due to the magnetic field.
  • Mixed
  • Participants discuss the setup of the problem, including the orientation of the wire and the magnetic field. There are attempts to calculate the cross product of the length vector and the magnetic field vector, with some questioning the components of the vectors involved.
Some participants have provided calculations for the components of the length vector and the resulting forces, while others express confusion about the directionality of the vectors and the application of the cross product. There is an ongoing exploration of the different segments of the wire and how they interact with the magnetic field.
Participants note that the problem may involve complexities due to the different orientations of the wire segments and the magnetic field, leading to varying interpretations of the force calculations. There is also mention of constraints related to checking work against a homework platform.
mvanella
A stiff wire 42.0cm long is bent at a right angle in the middle. One section lies along the z axis and the other is along the line y=2x in the xy plane. A current of 15.0 A flows in the wire-down the z axis and out the line in the xy plane. The wire passes through a uniform magnetic field given by B = (0.318i) T.
F = I * l x B
I am given all the elements, Current, length of wire, and Magnetic Field. I know that I have to figure out the cross product of the length and the magnetic field vectors, but this is where I have the most trouble.
If I am looking at my notebook I am using an xy plane where the y-axis is up/down and x is horizontal, same as we all learned in calculus. The z axis is the depth. Since the current is flowing down the z axis it is flowing into the page, so to speak.My graph diagram might look like this for the xy axis
...y
...| / y = 2x
_______|/___________ x
with the z axis as depth (in and out of the screen)
The length of each half of the wire is 0.21m.
To find the angle I use old trusty TOA (tanθ = o/a) to give me an angle of 63.4°
To find my x and y magnitudes I use SOH and CAH
x = cos(63.4°)*0.21m = 0.09m
y = sin(63.4°)*0.21m = 0.19m
and since Z is flowing into the page does that mean that my z vector is 0.21m?
Any help at this point is appreciated.
I am going to continue trying to work this out while I wait for help.
For the current flowing down the z axis, direction of current is of course in the [itex]\hat{-k}[/itex] direction. B is in [itex]\hat{i}[/itex] direction. So the force on this segment of the wire would be in [itex]\hat{-k}\times \hat{i}= \hat{-j}[/itex] direction.
For the segment of the wire in the xy plane, I is flowing in the first quadrant I suppose. So
the x and y components of vector I are positive. B is in [itex]\hat{i}[/itex] direction.
So the force on this segment , which is cross product of vector I and vector B, would be
in [itex]\hat{-k}[/itex] direction.
I thouight that L is a vector as well? At least that's what my book indicates. So is the cross product between L and B or between I and B?
well you can think of L as a vector or you can think of I as vector. The direction of both of them is same at any point...
Ok so I got components of "L" as 0.09i, 0.19j, 0.21k in meters. I took the cross product of those with the only component of B which is 0.318i in Tesla. I got a result of
-0.06678j and -0.06042k in Tm which gave me an angle of 47.9° below horizontal.
Now I was assuming that the magnitude of the force would be easy to find using pythagorean theorem of 0.06678^2 + 0.06042^2 = 0.00811 then multiplying that by the current of 15.0A to get: 0.121N but that doesn't make sense...
It should be at least greater than one Newton. Unfortunately I was using a rework of the problem on MasteringPhysics so I can't check my work. But I used the same process with different data and still ended up with a result of less than a Newton.
why would get components of L as 0.09i, 0.19j, 0.21k ? One segment is flowing down the
z axis and other segment is flowing in the xy plane. Work differently with these two segments, since the direction of force acting on these segments is different.
