Electron diffraction - effect of electron wavelength
Increasing the wavelength of electrons in diffraction leads to larger diffraction rings, as predicted by Bragg's law, which relates wavelength to diffraction angles. Conversely, decreasing the wavelength results in smaller rings due to reduced diffraction. The relationship between wavelength and atomic spacing is crucial; as the wavelength approaches the atomic scale, diffraction effects become more pronounced. Therefore, both increasing and decreasing the wavelength affect diffraction, but in opposite ways. Understanding these principles is essential for analyzing electron diffraction patterns effectively.
Molly1235
Hello, I know how electron diffraction works, and that if you decrease the wavelength of the electrons less diffraction occurs, so the rings are smaller, however was wondering what happens if the wavelength is increased? Is it just the opposite? More diffraction so larger rings?
I was also thinking that perhaps less diffraction happens if you increase the wavelength as well as if you decrease it, as the wavelength is getting further away from the atomic spacing of the graphite or whatever is being used.
Both made sense in my head so I wonder if anyone can help?
Thanks!
Molly :)
Hello,
The effect of the electron wavelength on the diffraction angles is described by Bragg's law:
n.lambda = 2.d.sin theta
with n the order of the diffraction, lambda the wavelength, d the distance of the diffraction grating (i.e. the distance between crystal planes) and theta the diffraction angle. With this law, you can see immediately the effect of a change in wavelength.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
