How Do Electrons Form a Bond in Covalent Bonding Despite Their Mutual Repulsion?
  • Thread starter Thread starter bronx
    Bonding Electron
The discussion centers on the principles of chemical bonding, particularly covalent bonding, and the apparent contradiction of like charges repelling while electrons form bonds. In a hydrogen molecule, two positively charged nuclei attract two electrons, which repel each other, creating a local equilibrium that defines the bond. This balance is similar to helium, where two electrons coexist around positively charged nuclei despite their mutual repulsion. The attraction between electrons and nuclei is not due to gravity but rather the interaction of instantaneous dipoles as atoms approach each other. The key to bond formation lies in quantum mechanics; according to Heisenberg's uncertainty principle, electrons can occupy a larger space when bonded, leading to lower kinetic energy and greater stability, thus facilitating the formation of chemical bonds despite the repulsive forces at play.
bronx
There's a rule bout unlike charges attract and like charges repel one another. How is it that in chemical bonding like in covalent bonding electrons form a bond or there is attraction from one unto the other. Isn't that ironic?
Chemistry news on Phys.org
Well, to take the simplest example of the bond in a hydrogen molecule, you have two positively charged nuclei, and two electrons. Each electron is attracted to both nuclei, but repelled by the other electron. Chemical bonds are then a sort of compromise; it's a local equilibrium where it would take more energy to smoosh them closer closer together or pull them further apart.
That two electrons can be in the vicinity of positively charged nuclei is not without precedent.
After all, Helium atoms have two electrons orbiting each of them and are stable, even though the electrons repel each other.
But isn't Hydrogen atom electrically neutral? One +p and -e, what is then the attraction between one over the other? Is it not gravity or something?
Forget about gravity. What you have, at long range, is the interaction of the instantaneous dipole. As the two atoms get closer, you will have the electron of one atom having a non-negligible overlap with the nucleus of the other atom.
Likes bronx
That's is more real I agree. thanks.
There is no attraction between the electrons and mutual repulsion of the electrons is rather an obstacle to bond formation. As others pointed out already, this repulsion is partially made off by the attraction of the nuclei, but this wouldn't explain bonding.
The real reason behind bond formation is a quantum mechanical one: According to Heisenberg's uncertainty relation, the average momentum of an electron will be the lower, the more space it can occupy. Lower momentum also means lower kinetic energy. In a molecule, an electron has the chance to be found on either of two atoms instead of only one before bond formation. Hence it can occupy more space and it's kinetic energy gets lower.
Likes bronx
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
