Electron shell transitions between levels - conceptual question
The probability of electron transitions between energy levels varies, with transitions from n=2 to n=1 generally being more common than those from n=4 to n=3. This is primarily due to the higher energy required to transition from outer shells, making lower energy transitions more likely. The context of these transitions often involves phenomena like X-ray fluorescence, where high-energy photons can displace inner shell electrons, leading to a cascade of lower energy transitions. The n=2 to n=1 transition is particularly notable as it corresponds to the K-alpha line, which is frequently observed. Additionally, outer shell transitions may be influenced by the Auger effect, complicating the overall transition probabilities.
jumbogala
Is the probability that an electron transitions from the N to M (n = 4 to n = 3) shell different than the electron going from L to K (n = 2 to n = 1)?
So basically, should I expect to see a lot more transitions from n = 2 to n = 1, than any other type of transition? If so, why?
I'm not really sure why this would be. Perhaps because you need more energy in the first place to knock electrons out of the higher levels? That's just a guess. Can anyone help me out, I'm curious if and why this is true.
What's the context of these transitions? Are you talking about something like X-Ray fluorescence, wherein a high energy photon displaces an inner shell electron, followed by a cascade of electrons falling into lower energy orbitals to make up for the vacancy?
In that case, n=2 to n=1 transition is most likely and the strongest observed transition (K-alpha line), see: http://en.wikipedia.org/wiki/File:XRFScan.jpg
With outershell electrons, there is also a competing effect called the Auger effect.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
