Calculating Distance of Electron in Electric Field
In summary, the conversation revolves around a problem involving an electron moving into a uniform electric field and calculating the distance it travels before coming to a rest. The conversation includes discussions on relevant equations, the use of conservation of energy, and the importance of attempting problems on one's own.
DPavel
An electron with a speed of 5 E6 meter/second moves into a uniform electric field with a value of 1,000 volt/meter. The field is parallel to the electron's motion. Calculate the distance it travels before being brought to rest.
You've provided the problem, but no attempt at a solution or even an attempt at stating relevant equations. The harder you try, the more we'll help you. Zero effort gets zero help.
wow that is very rude! the whole reason i posted it is because i am not sure where to begin. i am a PT major just trying to make it through this class. sheesh. next time, keep your mean comments to yourself!
multiply the charge of an electron by the electric field, this should give you a resultant force. divide the force by the mass of an electron to get the decelleration. so now u got the initial velocity, the decelleration and the final velocity (zero) which is enough to calculate the distance using: final velocity squared = initial velocity squared + 2 x acelleration x distance
negitron has a point. u must atleast attempt problems on your own if you want any hope of surviving the course. not just post it on the web coz u dnt feel like trying
but then the answer would be zero...would it not? because to find the distance you would have to divide that answer by zero??
You should not be surprised by the response if you read the forum rules. We do not answer your questions without any work, we do not attempt to guess at what you're thinking or asking, we provide support to students who has attempted problems and are having trouble. The template you used should have hinted at what you needed to provide.
For this question, do you know the force acted on a charge in a constant electric field?
i believe you have it all wrong. i am just trying to study for my final, and this is a chapter i have trouble with. and I've been searching for an answer for a few hours on this. anyway, i appreciate the help that you have given me. and really, to say that i am just posting it on the web because i do not feel like trying is...well, wrong. it was kind of a last resort. summer class for physics II is trying to teach a 15 chapters in 6 weeks with a book that I could not afford. So yes, I do use the internet to search for equations and this is the one problem that I cannot locate.
again, thanks for the help.
the K constant? 9 E 9 i believe..
You don't need that. Use conservation of energy. How much initial kinetic energy does the electron have? How much energy does it lose every meter it moves through the field? Do you have a formula for any of these things?
Actually in this question, you do not need the coulomb constant. If you know the electron is in a constant electric field, E, it experiences a force of F = qE where q is the charge or in this case, -1.602e-19 C. We also know that F = ma. Equating the two, you see that f = qE/m. At this point, we can use our kinematics. Remember, the force should be negative since it's an electron with negative charge and a positive electric field.
[tex]\begin{array}{l}
x_f = x_i + v_i t + \frac{{at^2 }}{2} \\
v_f = v_i + at \\
\end{array}[/tex]
So what we're looking for is the final position with this constant acceleration, a. We know that the initial position is 0 and our initial velocity is 5e6 m/s while the final velocity will be 0. Using the initial and final velocity, we can solve for 't' in the second equation. Finally, plug this value of 't' into the first equation and you can solve for [tex]x_f[/tex].
Oh yah, this is actually by far an easier method of solving it.
Not from what I've seen. DPavel knows how to work a crowd, hey?
Not from what I've seen. DPavel knows how to work a crowd. The squeaky-wheel approach to higher learning is one of the infallible methodologies. We can't fault him for not learning his lessons. :rolleyes:
no the answer wouldn't be zero, coz u will subtract initial velocity squared from zero then divide it by 2 x acelleration
let me knw what the answer is, i am interested.
DPavel, that's not a mean comment. It's a standard response to a post without effort. Note the "harder you try, the more we'll help you" part. Considering it's your first post, I think other people could be easier on you. Now, can you help us to help you?
"negitron has a point. u must atleast attempt problems on your own if you want any hope of surviving the course. not just post it on the web coz u dnt feel like trying"
Why don't you try? It's NOT even HARD.
lol. i am content with figuring out the problem. i dnt really need a numerical value. and yes it is a really simple problem.
you physics guys are funny. Dick, you may not think it is a hard problem, but for a girl who has only had one other class in physics and typically studies bones and muscles, it really is. Maybe you can think of a subject that you just couldn't grasp? idk. Or maybe you are just perfect in everything. Maybe you have forgotten how it was when you first learned this stuff? I feel like a lot of teachers forget this. And ralilu, thanks for the help, i am going to get back down to this problem right now and i will post the answer i come up with.
my final answer is 0.071 meters. Thanks all for your help, it really makes some sense now! Final on Thursday.
cool, that sounds correct. my advice for your final is try and understand the energy and work concepts the most and you will find that you can solve almost all of the problems in your course using a simple energy equation.
e.g in this problem: work done = change in kinetic energy
work = force times distance
change in kinetic energy = (1/2)(mass)(change in velocity)
gudluck! and i struggled with muscles and bones...
I wasn't talking to you when I said it's not a hard problem. I was talking to ralilu. Every problem is hard for somebody. Most problems are easy for somebody else. But if somebody else posts advice on a problem, I would expect them to be able to solve it, not post back saying send me the answer when you get it. Sheesh.
if u go back a few posts you will find that i did solve the problem i just didnt plug in the numbers...
i asked her to let me knw the answer coz i wanted to knw wether or not she solved it.
Ok. That's a good reason.
1. How do you calculate the distance of an electron in an electric field?
To calculate the distance of an electron in an electric field, you can use the equation d = F/qE, where d is the distance, F is the force on the electron, q is the charge of the electron, and E is the strength of the electric field.
2. What is the unit for distance when calculating the distance of an electron in an electric field?
The unit for distance when calculating the distance of an electron in an electric field is typically meters (m).
3. How does the strength of the electric field affect the distance of an electron?
The strength of the electric field directly affects the distance of an electron. A stronger electric field will result in a larger force on the electron, causing it to travel a greater distance.
4. Can the distance of an electron in an electric field be negative?
Yes, the distance of an electron in an electric field can be negative. This typically occurs when the electric field is directed in the opposite direction of the electron's motion.
5. Is there a limit to how far an electron can travel in an electric field?
No, there is no limit to how far an electron can travel in an electric field. However, the strength of the electric field and the force on the electron will decrease as the distance increases, eventually reaching a point where the electron will stop moving.
