Twoacross
- 9
Protons are bring accelerated through a potiential difference of 5.00 x 10^3 V in the gun of a particle accelerator. They must pass between two parallel deflecting plates that are 6.0 x 10^-2 m long and 2.0 x 10^-2 m apart with a potiential difference between them of 1.50 x 10^3 V?
Part 1 asks the kinetic energy of protons leaving the gun, I found it to be8.01 x 10^-16 J
Part 2 asks what is the velocity of the protons down the accelerator, I found that to be 9.79 x 10^5 m/s
Part 3 asks what is the electric field strength between the deflecting plates, i got 30 V / m
Part 4 asks what is the deflecting force on the protons between the plates, i got 4.80 x 10^-18 N
Part 5 asks what is the acceleration of the protons between the plates, i got 2.87 x 10^9 m/s^2
So the next part of the question asks: How much time is required for the protons to pass between the deflection plates?
These questions, i wasnt able to identify the right formulas to use, help is appreciated!
1. By how much are the protons deflected while passing between the plates?
2. What is the component of the protons' velocity perpendicular to the plates when they leave the region between the plates?
3. The protons eventually strike a flourescent screen 0.20 m beyond the end of the charged plates. How long does it take the protons to travel this distance?
So for the question in the first part and not in the revelant questions area i had used:
t = Ip * v, where Ip is the length of the plates and v is the velocity and i ended up with 5.87 x 10^4 s, using the v value found earlier which will be included as well. It sounded fishy since that's quite the wait so i was wondering if i had done something wrong. Other than that, the questions in the Revelant questions area, i wasn't able to pinpoint the correct logic and formulas to use, so if anyone could tell me what to do, it'll be greatly appreciated!
Thank you!
