Elementary Charge lab question?
To determine the mass of a single object from bags of varying amounts, the procedure involves analyzing the mass measurements as multiples of the individual object's mass. Dividing any two mass measurements can yield integer ratios that help identify this mass. While the teacher suggested formulas related to gravity and force, the focus should be on numerical analysis similar to Millikan's method for finding elementary charge. Plotting the mass data on a graph can reveal clusters that indicate multiples of the basic mass, aiding in the identification of the individual object's mass. This approach emphasizes data visualization over complex physics formulas.
Naru1019
I need to design a procedure for this lab.
I measured the mass of a couple of bags containing the same object in random amounts. Without looking at how many objects are in the bag i have to determine the mass of one object.
At first i thought that since each mass measured should be a multiple of the mass of one object, dividing any two of the masses will give a ration of numbers. The numerator and denominator represent integers that will help determine the mass of an individual object.
The teacher said it had to do something with formulas that concern gravity and force. Another group tried to use density and volume formula to solve it. I'm pretty stuck here, can anybody please help me??
I disagree with "formulas that concern gravity and force" so I may be on the wrong track here. It seems to me you are doing a lab to familiarize yourself with the methods used by Millikan to find the elementary charge. AFTER he measured all those charges, how did he get an estimate of the elementary charge? Just analyzing numbers, no physics formulas.
I suggest you check out this pdf on the Millikan experiment.
www.physics.uci.edu/~advanlab/millikan.pdf
The whole thing is interesting, though the bit on viscosity may well be beyond your present physics level. The very last section with the title "So you’ve at last got the charges on a bunch of different drops. Now what?" is exactly what you need.
Many people can "see it" more easily on a graph. Take a full sheet of graph paper with mass on the side (beginning at zero) and the bag number on the bottom and plot all your data. Look only at the lower part of the graph at first. Look for clusters of dots along horizontal lines. Each line should be at a mass that is a multiple of some basic mass (at a level where there may be no dots). That basic mass is what you are looking for.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
