AZINGLY SIMPLE! How to Calculate Electric Repulsion Force
  • Thread starter Thread starter thomasrules
    Charge Elementary
To calculate the electric repulsion force between two small spheres with a deficit of 1x10^8 electrons, first determine the charge of each sphere. Each sphere, having 1x10^8 more protons than electrons, has a charge of +1.602 x 10^-11 Coulombs. Using Coulomb's law, the force can be calculated with the formula F = k * |q1 * q2| / r^2, where k is Coulomb's constant, q1 and q2 are the charges of the spheres, and r is the distance between them. The discussion emphasizes the importance of correctly applying Coulomb's law to find the force at a separation of one meter. Understanding the charge of an electron and how to convert it into the total charge for the spheres is crucial for accurate calculations.
thomasrules
Calculating charge and force of electric repulsion
Calculate the force of electric repulsion between two small spheres placed 1m apart if each has a deficit of 1x10^8 electrons.
I tried this and only got r=1m and N=1x10^8
I don't know the equation needed for this please help..
Thomas
Do you know the charge (in Coulombs) of the electron? Just use that in the Coulomb force equation.
AM
so what would q be? Whats the charge on both spheres?
If each has a deficit of 10^8 electrons, each has 10^8 more protons than electrons. So each has a charge of +10^8 e, where e = -1 x charge of one electron. The charge of one electron is -1.602 x 10^-19 C.
AM
so its (1.602x10^-19)(10^8)=charge?
Well, that is one of the charges. The other one is the same. Do you know how to apply Coulomb's law to find the force at a separation of one meter?
AM
