Do EMF Sources Combine Conservative and Non-Conservative Electric Fields?
In summary: What's your understanding now?Then why there's drop in potential if there's no conservative electric field?There could be a combination of conservative and non-conservative field, perhaps?
tonyjk
227
Hello,
We know that the electric field generated by a changing magnetic field is not conservative. But, for example let' say we have an EMF source that has an internal resistor, the voltage drop across the source is equal to EMF-rI where r is the internal resistance. My question is, inside the EMF source, we have non-conservative electric field but also do we have conservative electric field due to its internal resistor? Please if someone didn't understand the question tells me.
Thank you.
Hi.
You have brought up two different issues. An emf source does not, by definition, have an internal resistor. A real source of emf, if it is located in a specific place, (often) has an equivalent circuit of a true emf in series with a series resistor. All the same rules apply to that resistor as the other resistors in the circuit.
The issue of the non-conservative field is a separate one, I think and this video deals with it quite well. He presents it in an entertaining way.
sophiecentaur said:
Hi.
Yes, Sorry I meant about an emf source having a non-conservative electric field plus an internal resistor like in a coil. we can say that inside the coil we have a conservative electric field due to its resistor?
Doesn't that video describe exactly the situation you describe (in effect)?
Okay, you mentioned before that an internal resistor is like a normal resistor. So yes it describes the situation. Just I was confused about the internal resistor and the difference between normal one because physically the coil is one object that has ideal coil + resistor.
Thanks anyway
But with one difference. You can't measure the voltage drop across it - and it's only an 'equivalent' component in as far as the loss mechanism can be anywhere and anything that's 'inside' the component. In your though experiment, you couldn't put a meter where the one in the video appears so you wouldn't get any paradoxical results. This stuff is quite confusing because of the temptation to assume that you really would get different results just by re-connecting a meter.
I'm not sure about this one because the resistor in question is distributed within the coil. Would the conservative field idea still apply?
Could there not be a combination of conservative and non-conservative field, perhaps?
Perhaps someone else could chime in, here?
Likes tonyjk
Having read around, I now find (why has it taken me so long?) that any vector field will be a combination of a conservative field and a solenoidal (non-conservative) field. Wikkers is a way into this. It makes good enough sense, when you think about it.
Likes tonyjk
1. What is EMF?
EMF stands for electromotive force, which is the voltage created by a battery or power source. It is the force that pushes electrons through a circuit.
2. What is internal resistance?
Internal resistance is the resistance within a battery or power source that impedes the flow of current. It is caused by the materials and structure of the battery and can affect the overall voltage and performance of the device.
3. How does internal resistance affect battery performance?
Internal resistance can cause voltage drops and decrease the overall power output of a battery. It can also cause the battery to heat up, leading to shorter battery life and potential damage to the device.
4. How can internal resistance be measured?
Internal resistance can be measured using a multimeter, by measuring the voltage drop across a known resistor, or by using specialized equipment such as an impedance analyzer.
5. How can internal resistance be reduced?
Internal resistance can be reduced by using higher quality materials in battery construction, minimizing the length of the battery's internal wiring, and ensuring proper temperature and charging conditions. Additionally, using multiple batteries in parallel can also decrease the overall internal resistance in a circuit.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
16K
10K
  • Electromagnetism
  • Electromagnetism
10K
