Magnetism and the Effect on a Freely Hung Loop
  • Thread starter Thread starter april_angela
    Loop Magnetism
A conducting loop hung on a rail experiences magnetic effects when a bar magnet approaches it. If the magnet's N-pole approaches, the loop is repelled, causing its area to increase slightly. Conversely, if the S-pole approaches, the loop is attracted, leading to a slight decrease in its area. The induced current in the loop opposes the change in magnetic flux, which explains the area changes. Understanding these principles is crucial for analyzing the loop's behavior in response to magnetic fields.
april_angela
Fig.35 shows a light and flexible conducting loop X freely hung on a smooth horizontal rail. A
bar magnet PQ approaches the loop from the right. Which one of the following descriptions
about this process is correct?
A If P is a N-pole, the loop will be repelled to the left and its area will increase slightly.
B If P is a S-pole, the loop will be attracted to the right and its area will decrease slightly.
C No matter whether P is a N-pole or a S-pole, the loop will be repelled to the left and its area
D No matter whether P is a N-pole or a S-pole, the loop will be repelled to the left and its area
can anyone help me with this qns? I've attached the diagram alrdy. I am not sure if the area will increase or decrease. and why?
Hint: If you have two current-carrying wires next to each other, do they attract or repel? Under what conditions?
attract when the current flowing in the same direction;vice versa?
Good. So how does that relate to this problem?
if the current repels the area increase? current attract area decrease? but idk how to relate to tis qns
Consider the induced current in the loop as the magnetic flux through the loop changes.
the induced current will be in the direction to oppose the motion. - repel the approaching magnet. means area increase?
Good.
Yes, but why? (Not for the reason above.)
if it repels the magnet. the area of the loop will widen and increase as if they are like straight conductors
