Calculating Speed of Object in Rotational System with Frictionless Bearings
  • Thread starter Thread starter phychal
    Energy
The discussion focuses on calculating the speed of an object in a rotational system involving a uniform spherical shell and a pulley. Key equations include the work-energy principle and the formulas for potential and kinetic energy. Participants emphasize the need to establish expressions for kinetic and potential energy for each moving object in the system. The relationship between the linear speed of the descending mass and the angular speed of the rotating objects is also highlighted as crucial for solving the problem. A clear understanding of these concepts is essential for determining the speed of the falling object.
phychal
A uniform spherical shell of mass M = 4.5kg and radius - 8.5 cm can rotate about a vertical axis on frictionless bearings. Rotational inertia formula for this object = 2/3 *m*r^3 A massless cord passes around the equator of the shell, over a pulley of rotational inertia I = 3.0 x 10^-3 kg * m^2 and radius = 5.0 cm, and is attached to a small object of mass m = .6kg. There is no friction on the pulley's axle; the cord does not slip on the pulley. What is the speed of the object when it has fallen 82 cm after being released from rest?
W = delta ke + delta pe
pe(gravitational)
pe(elastic)
work(linear/angular)
ke(angular/linear)
I'm not even sure where to start...
phychal said:
... Rotational inertia formula for this object = 2/3 *m*r^3 ...
You probably mean r2 here or the dimensions don't work.
pe(gravitational)
pe(elastic)
ke(angular/linear)
Start by finding expressions for each of the terms that you have listed above. Specifically, you have three objects that move, what is ΔKE and what is ΔPE for each of them? How is the linear speed of the descending mass related to the angular speed of the rotating objects?
