How Do You Calculate Energy Delivered to an Inductor Over Time?
  • Thread starter Thread starter sinned4789
    Energy Inductor
To calculate the energy delivered to a 4H inductor with a current described by i = 2t^2 - 1 Amps from t=1 to t=3, the energy differential is expressed as dw = Li di. The change in current di is determined to be 4t dt. The energy can be calculated using the integral of (2t^2 - 1)(4t) dt from 1 to 3 seconds. The poster seeks confirmation of their approach, which is affirmed as correct. The calculations align with the principles of energy in inductors.
sinned4789
the current through an element is i = 2t^2 - 1 Amps. if that element is a 4H inductor, what is the energy delivered to it from time t=1 to t=3.
energy in an inductor is dw = Li di
i = 2t^2 - 1
di = 4t dt
w = L integral[ (2t^2 - 1)(4t) dt ] from 1 to 3 seconds
i just want to confirm it with someone if i did it right or not. i felt like i did. thanks.
yeah, that's right
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
