Energy stored in the electric field of a capacitor
The discussion focuses on calculating the energy stored in the electric field of two cubical capacitors, each with an interior volume of 1.00 m³ and an internal field of 1.00 V/m. The energy stored in each capacitor is determined using the formula W = ½ CV², resulting in 4.425 x 10^-12 J for each capacitor. When the capacitors are combined, the interior field's magnitude and the energy of the combined configuration are analyzed, with the conclusion that assembling them does not release or consume energy.
  • Understanding of capacitor fundamentals, including capacitance and electric fields.
  • Familiarity with the energy storage formula W = ½ CV².
  • Knowledge of dielectric materials and their effect on capacitance.
  • Basic grasp of parallel capacitor configurations and their impact on total capacitance.
  • Learn about the effects of dielectric materials on capacitance and energy storage.
  • Explore the concept of electric field strength in capacitors and its calculation.
  • Investigate the principles of combining capacitors in series and parallel configurations.
  • Study the implications of charge redistribution in capacitors when assembled together.
Students studying electromagnetism, electrical engineers, and anyone involved in the design and analysis of capacitor systems.
jersey
The figure shows cross-sectional views of two cubical capacitors, and a cross-sectional view of the same two capacitors put together so that their interiors coincide. A capacitor with the plates close together has a nearly uniform electric field between the plates, and almost zero field outside; these capacitors don’t have their plates very close together compared to the dimensions of the plates, but for the purpose of this problem, assume that they still have approximately the kind of idealized field pattern shown in the figure. Each capacitor has an interior volume of 1.00 m3, and is charged up to the point where its internal field is 1.00 V/m.
Diagram 1
Diagram 2
Diagram 3 (This diagram has the same four sides and is empty on the inside)
(a) Calculate the energy stored in the electric field of each capacitor when they are separate.
(b) Calculate the magnitude of the interior field when the two capacitors are put together in the manner shown. Ignore effects arising from the redistribution of each capacitor’s charge under the influence of the other capacitor.
(c) Calculate the energy of the put-together configuration. Does assembling them like this release energy, consume energy, or neither?
Energy stored, W = ½ QV = ½ CV2 joules
Charge Q = CV where C is the capacitance in Farads
charge Q is measured in coulombs (C)
If the dielectric (the material between the plates) is a vacuum, Capacitance C = e0 (A / l) where A is the area of the capacitor plates, and l is the distance between them.
e0 is the permittivity of free space (8.85X10-12)
If the dielectric is another material, capacitance is given by:
C = e0 (A / l) where er is the relative permittivity, which varies between materials.
Putting capacitors in parallel increases the total capacitance:
C = C1 + C2 + C3 ...
a) C=8.85 x 10^-12 x 1/1
=8.85 x 10^-12
W= 1/2cV^2
=1/2 (8.85 x 10^-12) x 1.0^2
=4.425 x 10^-12 J
I'm stuck, am i even on the right track here?
you answered a) correctly
What is the formula for magnitude of the inner field?
  • · Replies 18 ·
  • · Replies 18 ·
