Entrance to centrifugal pump = pressure lost in entrance to container?
The discussion addresses the pressure loss experienced at the entrance of a container compared to that at the entrance of a hydraulic centrifugal pump. It confirms that there is an irreversible loss in stagnation pressure in both scenarios, primarily due to flow dynamics. The pressure loss at the pump entrance is acknowledged as significant, similar to that at the container entrance. The analysis of such pressure losses is typically conducted using the Darcy Weisbach equation or similar methodologies. Understanding these losses is crucial for accurate hydraulic system design and efficiency.
Femme_physics
Does the local pressure lost endured in an entrance to a container (k =1) equal to the same local pressure lost of an entrance to a hydraulic Centrifugal pump (in basic hydraulic with mostly ideal conditions - neglecting friction). Or do we ignore it as local pressure lost?
Hi Femme_physics. Not sure exactly what you're asking but there is an irreversible loss in stagnation pressure anywhere there is flow unless work is being done on the fluid. So there's an irreversible pressure loss at the entrance to a pump and there's an irreversible pressure loss for flow into or out of a vessel. We typically analyze that pressure loss using the Darcy Weisbach equation or similar method.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
