Entropy/ 2nd law of thermodynamics
The discussion revolves around calculating the entropy change when two equal masses of water at different temperatures, T1 and T2, are mixed isobarically and adiabatically. The initial approach using q = Cp dT led to an incorrect assumption of reversibility, prompting confusion about the correct method to find the equilibrium temperature. Participants suggest that finding the equilibrium temperature is crucial for determining the total entropy change, but there is uncertainty about how to accurately calculate it. The inclusion of vapor pressure considerations is mentioned, adding complexity to the problem. Overall, the discussion highlights the challenges in applying thermodynamic principles to this irreversible mixing process.
BingoMan
A mass of water at T1 is isobarically and adiabatically mixed with an equal mass of water at T2. Show that the entropy change in the universe is 2*m*Cp*ln[(T1 + T2)/(2*SQRT(T1*T2))]
I'm assuming
dS = dq/T
q = m Cp dT
At the very beginning I was just using q = cpdT and getting total entropy = to m Cp ln(T2/T1) but that might be because that takes the process as reversible and this is an irreversible function
Next, I tried to find the equilibrium temperature by setting q1(using T1 and Tf) and q2 (using T2 and Tf) = 0 but I don't believe that is true and I couldn't figure out a way to get the equation given in the question.
It seems like it would be simple but I must be missing something.
Please help
Is this answer as simple as finding the equilibrium temperature then using that to find the entropy change in both masses and subtracting those?? If that's the case, then how does one figure out the equilibrium temp because I tried that to no avail.
I'm assuming
dS = dq/T
q = m Cp dT
It is not a simple question.
I think you are expected to take into account the vapour pressure of the water and assume that it is saturated at all times.
AM
I thought I might have to do that but it is isobarically mixed so I do not know how to deal with that
