Calculating Entropy Change of a Wire Conduction
To calculate the total change in entropy for a metal wire in thermal contact with two heat reservoirs at different temperatures, one must consider the heat flow from the hot reservoir and into the cold reservoir. The entropy change for each reservoir can be calculated using the formula dS = dQ / T, where dQ is the heat exchanged and T is the temperature of the respective reservoir. It is essential to sum the entropy changes from both reservoirs, taking care to apply the correct signs for heat flow. The wire's own entropy change can be ignored, as the focus is solely on the reservoirs. The final total entropy change is obtained by adding the calculated changes from both reservoirs.
pizzafihop
Each end of a metal wire is in thermal contact with a different heat reservoir. Reservoir 1 is at a temperature of 752 K, and reservoir 2 is at a temperature of 345 K. Compute the total change in entropy that occurs from the condustion of 1096 J of heat through the wire.
dS = dQ / T
Which T should I use? Should I average them? Use only one? Divide one by the other?
dS = dQ / T
First of all, you have to ignore the entropy change of the wire. Then it is just a matter of heat flowing out of the hot reservoir and heat flowing into the cold reservoir without changing the temperature of either. Calculate the entropy change of the hot reservoir. Calculate the entropy change of the cold reservoir. Add them together (be careful of the signs - flow into is positive/flow out is negative).
AM
Thanks, I didn't realize I had to split the formula in 2 for each reservoir.
To calculate the total entropy change you have to sum the entropy changes of the parts.
Generally, you would divide the entire system into infinitessimal slices and do an integral of the heat flows/surface temperature into and out of each slice. In this case there is no temperature gradient within the reservoir so you can look at the reservoir as a whole. All the heat leaves or enters the reservoir at the same temperature. So just determine the entropy change for each reservoir and add them together to get the total entropy change for the system.
Once the wire heats up there is a stable temperature gradient along the wire so its thermodynamic state does not change. You are then left with only the entropy changes in each reservoir.
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
