Equation of Motion for a Pendulum
The discussion focuses on the equations of motion for a simple pendulum at small displacements. The main challenge is understanding how the z-component equation reduces while retaining both tension and gravitational force. It is noted that for small angles, tension approximates to mg, simplifying the x and y components. The necessity of dividing by mass is clarified as a means to convert the equations into a standard differential form. The Small Angle Approximation is suggested as a helpful concept for further understanding.
gumball
The question involves a simple pendulum, I am given three equations (1), (2) and (3) of motion for the bob at latitude (fi) for the x, y and z components.
the question then tells me to show that for small displacements meaning |theta|<< 1 (the angle between the string and the z direction in the centre of the x and y planes is very small) the three equations of motion will reduce to equations (4) (5) and (6).
my main problem is understanding how the equation in the z component reduces, especially regarding why the Tension remains as well as the force of gravity.
I also don't know the reason why we have to divide everything by mass.
[PLAIN]http://img802.imageshack.us/img802/4642/equationsofmotion.jpg
I understand when (theta) is very small, the Tension in the string is almost equal to (mg)
T = mg
this explains that in the x and y components the Tension becomes mg. but in the z component I don't understand why Tension stays as T, while still keeping mg in the equation.
as for mass, I am guessing mass is negligible because the tension is mg, thus mass cancels out, but still doesn't explain why the z component stays.
Look up Small Angle Approximation and see if that helps.
The reason for dividing by mass is to get it into a standard differential equation forum.
makes sense now, thanks for the help :D
