Equilibrium equation for a frame
  • Thread starter Thread starter princejan7
    Equilibrium Frame
The discussion centers on the free body diagram (FBD) for member BE in a frame analysis. It questions the exclusion of force P from the FBD, clarifying that the force at the pin is assumed to exert a reaction force Ex on member BE. The solution involves taking moments about the pin, which leads to the assumption that the moment at the pin is zero, allowing BE to rotate freely. The internal cut in the FBD is made close to the joint, thus not including P, but rather focusing on internal forces and external reactions. Understanding these dynamics is crucial for accurate equilibrium equations in frame analysis.
princejan7
http://postimg.org/image/scm11r483/
So when considering the free body diagram for member BE, why is the force P not included?
Does the Ex account for the bit of the P=210 that would act on member BE?
The problem statement seems to imply that the force is acting on the pin. The pin is then assumed to exert a force Ex on member BE. In the problem solution, moments are taken about the pin, so the force at E doesn't matter in this moment balance. However, the solution implicitly assumes that the moment at the pin is zero (i.e., BE rotates freely at the pin).
Did you solve for Ex? It's quite a bit of P.
In the FBD of the member, the internal cut is made an infinitesimal distance away from the joint, so it does not include P in your FBD of the member, just internal forces Ex, Ey, CD, and the external roller vertical reaction.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
