lsatwd
- 5
The problem has two thin metal bar electrodes, one setup to be positive and one setup to be negative. A metal circular disc is placed between the two bars. Why do the equipotential lines near the edge of the bar run parallel to the bar?
The setup looks kind of like this:
Code:
|-| 0 |+|
I'm unsure how to answer this question as I do not know what the circular disc in the middle represents. And how it factors into the question.
I have written in, "The lines near the edge of the bar runs parallel because electric field lines usually emerge perpendicular from the edge of conductors. And since equipotential lines, in turn, run perpendicular to E. Field lines, the equipotential line near the bar is parallel."
Aside from being a bit redundant, I feel this answer is insufficient since it doesn't seem to take the circular disc into consideration. Should the circular disc be a factor? Would the equipotential lines, closer to the circle, curve around it and no longer be parallel to the plate? I am confused.
