Equivalent capacitance in series/parallel
7 replies · 110K views · last reply
exi
What is the equivalent capacitance for the following schematic?
Note that C1 is 11 µF, and C2 is 3 µF.
http://img511.imageshack.us/img511/8051/questionzi5.png
[tex]C_{parallel} = C_1 + C_2 + C_3 + ... + C_n[/tex]
[tex]\frac{1}{C_{series}} = \frac{1}{C_1} + \frac{1}{C_2} + \frac{1}{C_3} + ... + \frac{1}{C_n}[/tex]
I tried the following:
1: Considered the four right-hand caps to be in parallel and add them as above, yielding 47 µF, and:
2: Added that 47 µF cap in series with the remaining 5 µF and 3 µF caps like so:
[tex]C_{eq} = \frac{1}{\frac{1}{5} + \frac{1}{47} + \frac{1}{3}} = 1.8051 \mu F[/tex]
But no go (and appropriately so, since the number seems a bit small). Where am I making a mistake?
[tex]C_{series} = \frac{1}{C_1} + \frac{1}{C_2} + \frac{1}{C_3} + ... + \frac{1}{C_n}[/tex]
The right-most three capacitors are in series. Find the equivalent capacitance of those three. That capacitance is then in parallel with the 4.0 uf capacitor. Find the equivalent capacitance for the parallel part. That is in series with the other two.
AM
AM
That makes a hell of a lot of sense.
I've got one remaining shot at this problem, so I would much appreciate it if someone could double-check me on this conceptually (oddly, the number still seems low at first glance, but I'm completely new to caps):
[tex]C_{rt series} = \frac{1}{\frac{1}{24} + \frac{1}{11} + \frac{1}{8}} = 3.8824 \mu F[/tex]
[tex]C_{rt parallel} = 3.8824 + 4 = 7.8824 \mu F[/tex]
[tex]C_{eq} = \frac{1}{\frac{1}{5} + \frac{1}{7.8824} + \frac{1}{3}} = 1.5147 \mu F[/tex]
Thanks for the look-over; 1.5147 is the answer.
Surprised to see it so low, but it's the answer.
somebody help me solve this question please
find eq capacitance when each capacitoras capaccitance C
h
Hand-drawn circuit schematic of capacitors in a network between two terminals, with a labelled capacitor C and a battery symbol labelled E on the left, leads running to the right.
hi please anser this
this is not good see next post
  • Circuit schematic of a capacitor network between terminals X and Y, with capacitors labelled 2F, 1F, 1F, 4F, 1F and 1F in series and parallel branches, beside answer choices a. 20F, b. 23F, c. 22F, d. 21F.
please answer this
regards
  • Circuit diagram of capacitors between terminals X and Y, with values 2F, 1F, 1F, 4F, 1F, 3F, 2F, 3F and C, and the question: What is the value of C such that equivalent capacitance across x-y is 5F. Options a. 20F, b. 23F, c. 22F, d. 21F.
