Equivalent Resistance Calculation for Resistors in a Circuit
The discussion focuses on calculating the equivalent resistance between points A and B in a circuit with six resistors. The initial approach involved combining resistors R3, R4, and R5 in parallel, then adding R6 in series, leading to an incorrect total resistance of 9.33 Ohms. Clarification revealed that the final equivalent resistance should actually consider R1 and R2 in parallel with the combined resistance of R3, R4, R5, and R6. The correct method involves recognizing that R1, R2, and the equivalent resistance of R3, R4, and R5 are all in parallel. This understanding helps to accurately calculate the equivalent resistance for the circuit.
cjames9001
Find the equivalent resistance between points A and B shown in the figure . Consider R1 = 4.8 Ohms, R2 = 2.5 Ohms, R3 = 3.7 Ohms, R4 = 4.4 Ohms, R5 = 4.1 Ohms, and R6 = 6.4 Ohms.
I got 9.33 by adding resistors 3,4,5 in parallel [1/(1/R3+1/R4+1/R5)] and added that to R6 which is in series with the equivalent of 3,4,5 and I added 1,2 In parallel [1/(1/R1+1/R2)]. My question is that obviously I am not combing the right resistors as parallel or series, can someone help me on this? I have also tried the equivalent of 3,4,5 in parallel and adding that to the equivalent of 1,2,6 in parallel which I believe is about 2.66 anyways I've tried a few other combinations as well and cannot seem to figure out which ones I am supposedto add in parallel and which ones to add in series
Your approach looks okay, but I'd check your math.
First, you found an equivalent resistance for R's 3, 4, & 5 which are in parallel. Let's call that R345. What value did you get?
Then you added R345 in series with R6 and got 9.33Ω. Call that R3456. That seems a bit high to me.
Perhaps you should lay out your calculations here and we can see what's going on.
The 9.33 I Got was the final answer.
This is what I did:
First R345=[1/(1/R3+1/R4+1/R5)]=[1/0.7414]=1.349 Ohms
Then I took R6= 6.4 Ohms and added it to 1.349 to get 7.749 Ohms
Then I Got R12=[1/(1/R1+1/R2)]=[1/0.608]=1.644 Ohms
Lastly I added 1.644 Ohms to 7.749 And got 9.39 Actually, Sorry.
This is what I did:
Excellent up to here.
Oops. The last two resistors (R12 and R3456) are in parallel, not series.
Actually, the value for R3465 is in parallel with R1 and R2, so you could find the final result from there by doing the parallel calculation on the three.
Ok, That worked, I'm a little confused as to why getting R3456 Is Parallel to R12? and Why wouldn't getting R126 And Adding it In series to R345 doesn't work? Thanks for your help so far by the way
Draw a picture with R1, R2, and R3456. You'll see that all three are in parallel (they all have their ends connected to node A and node B).
Ok I see what you mean, Thanks Again!
