How Can Fourier Series be Used to Expand a Continuous Function of Period 2L?
Any continuous function with a period of 2L can be expressed as a Fourier series, represented by the formula f(x)=a0/2 + ∑(an cos(nπx/L) + bn sin(nπx/L)). To derive the coefficients bn, one must multiply f(x) by (1/L)sin(mπx/L) and integrate from -L to L. The orthogonality of sine and cosine functions simplifies the integration, leading to the conclusion that bn can be expressed as bn = (1/L)∫(-L to L) sin(nπx/L)f(x) dx. The final result shows that the specific index used (n or m) does not affect the outcome, confirming the relationship for bn.
blueyellow
please help on this question
Any continuous function of period 2L can be expanded as a Fourier series
f(x)=a0/2+∑(from n=1 to∞) (ancos(n pi x/L)+bnsin(n pi x/L))
Using ∫(from -L to +L) sin(m pi x/L)sin(n pi x/L)dx=L kronecker delta m n
Show that
Bn=1/L∫(from -L to+L) sin(n pi x/L)f(x) dx
i am seriously stuck on this - kinda can't stand proof questions
thanks in advance
you must multiply f(x) by (1/L)sin(m pi x/L) and then integrate from -L to L in order to obtein:
<br /> \frac{1}{L}\int_{-L}^{L}sin(\frac{m\pi x}{L})f(x)dx=\frac{a_{0}}{2L}\int_{-L}^{L}sin(\frac{m\pi x}{L})dx+\sum a_{n} \frac{1}{L}\int_{-L}^{L}sin(\frac{m\pi x}{L})cos(\frac{n\pi x}{L})dx+\sum b_{n} \frac{1}{L}\int_{-L}^{L}sin(\frac{m\pi x}{L})sin(\frac{n\pi x}{L})dx<br />
then just apply the previous property that you mentioned and the fact that sin and cos are ortogonal function:
<br /> \int_{-L}^{L}sin(\frac{m\pi x}{L})cos(\frac{n\pi x}{L})dx=0<br />
but how do i get rid of th a0 and summation signs?
i tried what accatagliato said but 1)i couldn't get rid of the a0, and 2) i ended up with sin (n pi x/L) on a denominator
<br /> \int_{-L}^{L}sin(\frac{m\pi x}{L})dx=0<br />
because the sin function is an odd function and the interval of integration is symmetric. In fact:
<br /> \int_{-L}^{L}sin(\frac{m\pi x}{L})dx=\int_{-L}^{0}sin(\frac{m\pi x}{L})dx+\int_{0}^{L}sin(\frac{m\pi x}{L})dx<br />
changing x --> -x in the second integral
<br /> \int_{-L}^{0}sin(\frac{m\pi x}{L})dx+\int_{0}^{-L}sin(\frac{m\pi x}{L})dx=0<br />
For the summation:
<br /> \sum_{n} b_{n}\delta_{nm}=b_{m}<br />
thanks
im so sorry but what am i supposed to now do with b m (b subscript m)?
if i substitute the last equation in, the b n disappears, so then i can't actually do what they ask me to do in the question cos in the question they ask me to show that b n equals something
after substitution you obteined:
<br /> b_{m}=\frac{1}{L}\int_{-L}^{L}sin(\frac{m\pi x}{L})f(x)d<br />
nothing changes if there is n or m in the final result, you can call the index however you want, so this result transforms into:
<br /> b_{n}=\frac{1}{L}\int_{-L}^{L}sin(\frac{n\pi x}{L})f(x)d<br />
