Expected Sequences in a Random Events
The discussion centers on the expected number of heads when tossing a fair coin eight times. One participant suggests that the expected value of heads is 3, derived from the probability of getting heads. However, clarification is sought on whether the question pertains to the total number of heads expected or the longest sequence of consecutive heads. The distinction between these two interpretations is emphasized, as they yield different expected outcomes. Understanding the correct question is crucial for calculating the expected values accurately.
AliDimayev
How many heads in a row would you expect to find if you toss a fair coin 8 times?
I am thinking that the probability of 3 heads is 1/8 and since you have 8 tosses, that would give an E(x) of 1. So I am guessing that 3 is the number of heads one would expect to see in a fair coin is tossed 8 times. But I am not sure... Any help?
You can do this in two ways, the basic method and the shorter method.
The basic way is to use the definition of E(X)= ∑all x x*P(X=x)
Write out in a tabular form, the distribution
x
P(X=x)
x is the number heads obtained, so x goes from 0 to 8.
The other way is to see if the question can be fitted to a special type distribution.
I need some clarification: which question is of interest:
1) How many heads would you expect to occur during 8 flips of a fair coin?
2) If a fair coin is flipped 8 times, how long a sequence of consecutive heads would you expect to occur? (I phrased this from your wording "How many heads in a row...")
These questions are not the same.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
