Why Is My Converted Galvanometer Not Matching Standard Ammeter Readings?
The discussion centers around issues faced when converting a galvanometer into an ammeter, specifically the discrepancies between the galvanometer readings and those of a standard ammeter. Key advice includes ensuring proper placement of connections to avoid resistance errors and using a variable resistor for fine-tuning the readings. Participants emphasize the importance of measuring millivolts directly across the shunt rather than including additional resistance from connectors. It is also noted that exact calculations for resistance may not be necessary, as practical adjustments can improve accuracy. Overall, the conversation provides valuable troubleshooting tips for achieving accurate ammeter readings with a converted galvanometer.
ajaykrishna90
I am trying to convert galvanometer into an ammeter. But after finding Galvanometer resistance and shunt values, and cut a wire according to that thickness and connected. But still, the galavanometer reading is not similar to that of the standard ammeter reading connected in the circuit. Any one can help me please? In detail.
And, what is that resistance?
What wire? What resistance?
What current are you trying to measure?
Likes berkeman
I've found that placing a variable resistance on the order of 1/4 - 1/2 the coil resistance is useful as you can never quite get the shunt wire correct and the resistor will allow you an added adjustment.
Don't obsess over exact calculations as neither the meter resistance nor shunt will be exact.
Also, don't attach the meter at the far ends of the shunt because the resistance of the connections will contribute error. Rather, attach the meter to the shunt a little ways in from one connection. Then, move the other meter lead along the length to get the correct reading while a test current flows.
- Reference Kelvin Connection.
Hope this helps a bit.
- Mike
Mike bro thanks a lot. Its great. Got some new tips. I will try. Thanks again.
Mike pointed out the most common beginner's mistake.
Think about it - you're using the galvanometer as a voltmeter to read the milivolts across your shunt, which is probably only milli-ohms.
Here's a picture from a Kelvin link as Mike suggested
http://www.allaboutcircuits.com/vol_1/chpt_8/9.html
You need the millivolts across the shunt itself,
NOT the millivolts across the shunt PLUS millivolts across the connectors.
I used to cut my shunt wire a little long so there's room for the current connections outside my meter connections.
old jim
Thanks a lot
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
