Exploring Scalar Multiplication: u & v in V
I can be a bit of a knot-head sometimes!)Just remember to ask yourself if the definitions and axioms hold for any scalar and any vector - if they don't then they need to be revised ...
ryan8642
24
u and v are contained in V
Lets say the scalar multiplication is defined as:
ex.
ku=k^2 u or ku = (0,ku2) u=(u1,u2)
does this mean that this is also the same for different scalar m?
mu=m^2 u or mu = (0,mu2) u=(u1,u2)
and does this mean the same for any vector v
kv=k^2 v or kv = (0,kv2) v=(v1,v2)
Is this correct?
Axioms 7,8,9 contain the 2 different scalars as well as vectors. it really confuses me.
Can someone please put me on the right track :s
_____________
so u guys know and I am not confusing you guys i showed 2 examples there to help show my problem.
Ex 1.
does this then mean that this is also the same for different scalar m?
and also this for any vector v
_____________________
addition u+v=(u1+v1, u2+v2)
ex.. axiom 8 (to help explain my problem)
using what is described above.
(k+m)u = ku + mu
(k+m)(u1,u2)=k(u1,u2) + m(u1,u2)
(0,(k+m)u2)=(0,ku2) + (0,mu2)
(0,(k+m)u2)=(0,ku2+mu2)
(0,(k+m)u2)=(0,(k+m)u2)
LS=RS therefore axiom 8 holds for the set.
now using just ku=(0,ku2)
(k+m)u = ku + mu
(k+m)(u1,u2) = k(u1,u2) + m(u1,u2)
((k+m)u1, (k+m)u2) = (0,ku2) + (mu1,mu2)
((k+m)u1, (k+m)u2) = (0+mu1, ku2+mu2)
(ku1+mu1,ku2+mu2) = (mu1, ku2 +mu2)
LS ≠ RS so axiom 8 doesn't hold for the set.
hopefully that helps explain my problem...
which way is correct?? please help!
Not clear why this should confuse you ... the definitions are general and have to work for any vector in the vector space... so they also work for any pair of vectors each a member of the vector space.
Helps if you state the axiom in question - not everyone numbers them the same. eg. http://en.wikipedia.org/wiki/Vector_space#Definition
Lets start by asserting that ##\vec{u}=(u_1,u_2)## and ##\vec{v}=(v_1,v_2)## are both members of the same vector space - so I don't have to keep writing it out. Let's look at your examples:
##k\vec{u} = (0,ku_2)##
OK - and this should work for any other scalar ##m \neq k## and for any other vector ##\vec{v} \neq \vec{u}## ... the definition has to work for any vectors in the space.
##(k+m)\vec{u} = k\vec{u} + m\vec{u}##
##(k+m)(u_1,u_2)=k(u_1,u_2) + m(u_1,u_2)##
##(0,(k+m)u_2)=(0,ku_2) + (0,mu_2)##
##(0,(k+m)u_2)=(0,ku2+mu_2)##
##(0,(k+m)u_2)=(0,(k+m)u_2)##
You are using the distributive property for scalar multiplication.
The axiom says that ##(a+b)\vec{v}=a\vec{v}+b\vec{v}##
We need to be careful...
##LHS = (a+b)\vec{v}= (0, (a+b)v_2## from the definition.
##RHS = a\vec{v}+b\vec{v} = (0,av_2)+(0,bv_2) = (0, (a+b)v_2) = (a+b)\vec{v}##
Then we can observe that RHS = LHS and so the distributive law holds according to the rule for adding vectors. Explicitly separating the LHS and RHS like this helps to keep confusion at bay.
Notice that it does not matter what we call the scalars - you used k and m, I used a and b: it makes no difference to the math.
After all - the number "2" is a scalar - how does the vector know if that scalar is a k or an m or an a or a b or a whatever?
now using just ##k\vec{u}=(0,ku_2)##
##(k+m)(u_1,u_2) = k(u_1,u_2) + m(u_1,u_2)##
##((k+m)u_1, (k+m)u_2) = (0,ku_2) + (mu_1,mu_2)##
Nonsense! You did not follow the rule for scalar multiplication ... of course you got a different result!
Just as the rule works for k and m so it also works for any other scalar, and (k+m) is a scalar and so is m.
The letters are just labels and don't have any intrinsic meaning to themselves. You could as easily use a and b and (a+b) or fruit and vegetable names or geometric shapes.
If we have a scalar called "bob" then I'd write ##(bob)\vec{u}=(0, (bob)u_2)##
okk,
Thanks for the detailed explanation!
That clarifies what i thought
No worries: it is easy to get tied up in knots about this stuff.
1. What is scalar multiplication?
Scalar multiplication is an operation that involves multiplying a vector by a scalar (a number). This results in a new vector with the same direction as the original vector, but with a different magnitude.
2. What is the purpose of exploring scalar multiplication?
The purpose of exploring scalar multiplication is to understand how multiplying a vector by a scalar affects its properties, such as length and direction. This concept is important in linear algebra and has many applications in physics, engineering, and computer graphics.
3. What are u and v in relation to scalar multiplication?
In scalar multiplication, u and v represent vectors in a vector space V. The operation involves multiplying a scalar by a vector, so u and v are used to represent the vectors being multiplied.
4. How is scalar multiplication calculated?
To calculate scalar multiplication, you simply multiply each component of the vector by the scalar. For example, if u = [1, 2, 3] and the scalar is 2, the result would be [2, 4, 6]. This can also be represented using the formula k * u = [k * u1, k * u2, k * u3], where k is the scalar and u1, u2, and u3 are the components of the vector u.
5. What are some properties of scalar multiplication?
Some properties of scalar multiplication include:
  • Scalar multiplication is commutative: k * u = u * k
  • Scalar multiplication is associative: (k1 * k2) * u = k1 * (k2 * u)
  • The scalar 1 acts as the identity element: 1 * u = u
  • The scalar 0 acts as the zero vector: 0 * u = [0, 0, 0]
  • Scalar multiplication distributes over vector addition: k * (u + v) = k * u + k * v
  • Linear and Abstract Algebra
