Exploring the Coriolis Effect: Constant Velocity Circular Motion
In summary, the Coriolis Force is a fictitious force that is used to explain the behavior of an object that is moving without a force acting upon it.
boa_co
Hi, everyone
We were told in class that the Coriolis Effect is due to the change in the radius in circular motion.
But an objtct moving with constant velocity on the edje of the circular system, like on the equator still experiencing Coriolis force, because the cross product 2wXv is not zero.
Why is that? There is no change in the radius, so what gives?
See [thread=393932]this recent thread[/thread].
Your instructor misspoke, or you misinterpreted what he said. In any case, you are correct: An object moving tangentially in a rotating frame will experience a Coriolis force, even though there is no radial motion.
O.K. It's a bit more clear now. But where does the Coriolis Effect come from then?
It is not a real force it is more like an imaginary force bcause of the frame of reference you have chosen .
It's practical to first discuss two effects separately, and later combine them again.
- There is the case of tangential velocity (with respect to the rotating system), but no radial velocity. Then you get the effect that is the subject of the https://www.physicsforums.com/showthread.php?t=393932" that DH pointed out in an earlier message.
- There is the case of radial velocity, but no tangential velocity (initially).
In the case where the centripetal force is precisely enough to sustain the circumnavigating motion there is no radial velocity. To have some inward/outward radial velocity there needs to be a either a surplus of centripetal force, or not enough of it.
The left hand side of the animation shows an object moving along an ellipse-shaped trajectory. A centripetal force sustains that trajectory, the animation depicts the case where the strength of the centripetal force is proportional to the distance to the central point.
Interestingly, the ellipse-shaped trajectory can be thought of as decomposed in a circle and an epi-circle.
The right hand side of the animation shows what the motion looks like as seen from a point of view that is rotating with constant angular velocity. As you can see the animation combines the cases of motion in radial direction and motion in tangential direction.
When a mass has a velocity with respect to the rotating system there is a tendency to deflect. This tendency to deflect is equally strong in all directions.
Short answer:
It comes from trying to use Newton's second law in a regime where Newton's second law isn't valid.Long-winded answer:
Let's use the merry-go-round example of the centrifugal force and Coriolis effect. You are on the merry-go-round and throw a ball to someone else on the merry-go-round. Someone else standing on the ground outside the merry-go-round is watching this affair.
The behavior of the ball as perceived by that outside observer is easy to explain. Once the ball has left your hand the only force acting on the ball is gravity. The ball follows a nice simple arc, pretty much the same as the arc that would have been followed if the ball was thrown by someone standing on the ground. In particular, the only curve is vertical. The horizontal component of the ball's trajectory follows a straight line. The relevant equation is good old F=ma.
The behavior of the ball as perceived by you is a bit harder to explain. The trajectory curves both vertically and horizontally. If you want to explain things via F=ma, there must be some horizontal component to the force. There is of course no real force that is curving the ball horizontally. The problem is trying to use F=ma where F=ma is not valid.
That said, there is nothing wrong with creating those fictitious forces to explain the ball's trajectory. It does work. It is important to always remember that those forces are not quite real. They are called fictitious forces for a good reason.
When no force acts upon an object and the object's motion is viewed from a non-inertial frame of reference, then the object appears to accelerate. In order to make this result consistent with F=ma, a fictitious force is postulated. For certain cases, this force is classified as a Coriolis force. (In other selected cases, the fictitious force is called a centrifugal force.) Relative to an inertial frame, these fictitious forces are not required, since Newton's 2nd law accurately governs the motion of an object relative to every inertial frame.
Thanks for your answers but it is just a bit fuzzy yet. Does anyone have a link to an article or some kind of resource about Coriolis?
Related to Exploring the Coriolis Effect: Constant Velocity Circular Motion
What is the Coriolis Effect?
The Coriolis Effect is a phenomenon that describes the apparent deflection of moving objects on the surface of the Earth due to the Earth's rotation. This effect is caused by the difference in linear velocities between different latitudes.
How does the Coriolis Effect affect objects in constant velocity circular motion?
The Coriolis Effect causes objects in constant velocity circular motion to appear to deviate from their intended path, as seen from a stationary observer on the Earth's surface. This is because the object's linear velocity is constantly changing due to the rotation of the Earth.
What factors influence the strength of the Coriolis Effect?
The strength of the Coriolis Effect is influenced by the speed and direction of the moving object, as well as the latitude at which it is located. Objects moving at higher speeds or at higher latitudes will experience a stronger Coriolis Effect.
Can the Coriolis Effect be observed in everyday life?
Yes, the Coriolis Effect can be observed in everyday life. One common example is the direction of water draining in a sink or bathtub. In the Northern Hemisphere, the water will appear to rotate counterclockwise, while in the Southern Hemisphere it will rotate clockwise due to the Coriolis Effect.
How is the Coriolis Effect used in meteorology?
Meteorologists use the Coriolis Effect to explain the rotation of large-scale weather systems, such as hurricanes and cyclones. The Coriolis Effect causes these systems to rotate counterclockwise in the Northern Hemisphere and clockwise in the Southern Hemisphere.
  • Classical Physics
  • Astronomy and Astrophysics
