What is the relationship between heat, temperature, and measurements in joules?
Heat is energy measured in joules, while temperature indicates the energy level of a substance. The relationship between heat and temperature can be expressed using the formula Q = mc(dT), where Q is heat in joules, m is the mass of water, c is the specific heat capacity, and dT is the temperature change. In the experiment, water is heated by passing current through a coil, and temperature changes are recorded to calculate heat energy. The results indicate that the relationship between current and temperature increase aligns with Joule's Law, confirming the direct correlation between electrical energy and thermal energy.
tomMccune
Hi everyone,
I have an investigation to carry out for my Junior Certificate in Ireland. What I'm not sure about is the link between heat and temperature. I know that heat is energy, and temperature is the measurement of this energy, but I'm not sure what the link between celcius and joules is.
1. Measure the relation between the current of a circuit and the heating effect produced by that circuit2. Joule's Law - W = (I^2)(R)(t) (I'm sure this comes into it somewhere, my teacher has brought it up.
3. The way that my partner and I have carried out the experiment is:
We would measure 50ml of water and pour it into a polystyrene cup. We would then use a digital thermometer to get a reading of the temperature of the water as a control. This varied each time we got new water and measured it, probably due to weather, humidity etc. We would connect a battery to a rheostat (variable resistor), then to an ammeter, then to a wire coil, which would be submerged in the water in the polystyrene cup, then back to the other battery terminal. So, we have been waiting 8 minutes for the water to heat up, each time with a different current, then measuring the temperature of the water and the increase from the control. How would this be relavent to a measurement in joules (What formula would I use to convert my readings in Celcius to Joules?)? I don't get it at all.
Here are our results (A little weird, but we can... edit them, I know they're supposed to be directly related).
Thanks for any help, I hope I've been clear enough.
Tom.
use Q=mc(dT)
Where is the mass of water
c is the specific heat capacity of water
dT is th temperature difference.
Thanks. To see if I've got it right:
Q (heat in joules) = m (mass of water, 50ml/cc) x c (heat capacity of water, 4.186j/cm2) x dT (Difference from control, 0.03'C)
= 6.279J
Sorry if I got that completely wrong, I've never done anything like that before.
yep, that would be the correct way to calculate it.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
