Express electrostatic potential as a Fourier integral
zheng89120
The charge distribution of an atomic nucleus is modeled by the Gaussian distribution:
p(r) = A exp(-r2/a2)
Obtain the Fourier transform of p(r), and use the result to obtin an expression for the potential as a Fourier integral.
Fourier transform and electrostatics
I found the Fourier transform to be A*pi3/2*a3 exp(-1/4*a2k2)
How would you obtain the electrostatic potential (I suppose V) as a Fourier integral?
Express \rho(r) as a Fourier integral and then substitute that into the integral for calculating the potential.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
