Falling Weight Attached to a Wheel and a Sphere
The discussion revolves around calculating the acceleration of a falling weight that is connected to a wheel and a sphere via a string. The problem involves multiple masses and their respective moments of inertia, specifically for the sphere and the wheel, which are noted to spin without friction.
  • Mixed
  • Participants discuss the relationship between tensions in the string and the torques acting on the system. There are attempts to set up free body equations for the components involved, and questions arise regarding the net moment of inertia affecting the acceleration.
Some participants have offered guidance on creating unknowns for the tensions in the string and relating them to the equations of motion. There is an acknowledgment of the complexity due to multiple components, and while one participant expresses understanding, others are still seeking clarification on the approach.
There is mention of omitted values from the original problem statement, which may be relevant for calculations. Additionally, one participant notes a mistake regarding the use of diameter instead of radius in calculations, indicating potential confusion in the setup.
Como Bluff
How do I calculate the acceleration of the falling weight? It is hanging from a string which goes through a wheel, and is attached to a sphere with thin walls. The string doesn't stretch and the wheel and the sphere spin without friction.
The fact that the weight is connected to multiple masses is the problem. How does one calculate the net moment of inertia that is affecting the acceleration of the falling weight?
For the sake of simplicity, I left out the values given in the original statement of the problem; these are of course available upon request.
The moments of inertia for the objects in the problem:
Jsphere = [itex]\frac{2}{3}[/itex]mr2
Jwheel = [itex]\frac{1}{2}[/itex]mr2
Thanks!
Deal with the tensions in the string, relating them to the torques.
Thanks for quick reply haruspex! I don't quite get it yet. Could you elaborate your answer a little more?
Create unknowns for the tensions in the two sections of string. (They will not be the same.) Do the usual free body equations for each of the three massive components. You can relate all the accelerations and angular accelerations through the radii. You should have three equations with three unknowns (the two tensions and the acceleration).
I got it now, thanks!
(I had also made the classic mistake of using the given diameter as the radius, which was needed to calculate the mass of the wheel from the moment of inertia..)
15K
  • · Replies 97 ·
  • · Replies 30 ·
