Feasibility of fission reactor at centre of Earth
The discussion centers around J. Marvin Herndon's proposal of a fission reactor at the Earth's core to explain the geomagnetic field. Critics argue that gravitational forces at the Earth's center would prevent heavy elements from separating as Herndon suggests. The inner core, composed of solid material under extreme pressure, generates heat primarily through the radioactivity of isotopes like potassium-40, which some believe is the main source of core heat after initial cooling. The conversation also touches on the nature of the inner core, emphasizing that it remains solid due to the behavior of seismic waves, and discusses the potential for fission in solid uranium under specific conditions, highlighting the role of moderators in nuclear reactions.
verdigris
There's a a paper by J Marvin Herndon about the feasibility of a fission reactor about 5 miles wide at the centre of the Earth,which could generate the geomagnetic field.Someone said in New Scientist magazine that because gravitational forces are nearly zero at the Earth's centre then the heavy chemicals mentioned by Hearndon wouldn't separate out on the basis of density as he suggests.
http://www.understandearth.com/Herndon%20JGG93.pdf
Quite right indeed. Moreover the inner core is solid under the extreme pressure. However, all the unstable isotopes anywhere within the Earth, perhaps most abundantly 40K just continue their usual radioactivity and thus generate heat. Some think that this process is the main cause of the heat of the core after initial cooling.
Others have other ideas of course.
qhttp://nujournal.net/core.pdf[/URL]
Just showing it for educational purposes, how far one can go scaremongering in order to get into the limelight.
Andre said:
"the inner core is solid under the extreme pressure. "
Solid lumps of uranium do naturally undergo fission such as those found in 1972 in a mine at Oklo, Gabon.But the neutrons need to be slowed down (at Oklo water was the moderating material).There are many elements that can act as moderators - carbon is one.Also the core of the Earth does not have to be solid if the core temperature is high enough.Some moderating materials have atoms displaced by neutrons and these atoms stay in the moderating material with high potential energy that can suddenly be released by a temperature rise(Wigner enrgy that caused the fire at Windscale).
verdigris said:
The inner core is solid because s-waves travel through; the p-wave loses energy in the form of an s-wave at the liquid/solid, outer/inner core boundary. This happens because p and so-called sv- waves form a coupled system.
We have little shade but plenty of wind on my property. The upshot of this is that I have to be judicious in how/where I put up shade-creating barriers in various places around my property to maximise shade without unduly large windage. My property is an irregular polygon and not aligned with the cardinal axes, so it is not easy to tell where the shade will be at a given time. For example, I have put up an umbrella next to our pool, but it can only shade the southish-side of the pool, and...
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
