Calculating Field Direction and Magnitude for Levitating Copper Wire
To calculate the field direction and magnitude for a horizontal copper wire levitating with a current of 50 A moving east, use the formula F = IL x B = mg. Here, F represents the magnetic force, I is the current, L is the length of the wire (1.0 m), B is the magnetic field strength, m is the mass of the wire, and g is the acceleration due to gravity (9.81 N/kg). The mass of the wire can be determined from its volume and density, considering its diameter of 0.10 cm. Understanding the principles behind the equation is crucial for proper application. This approach ensures accurate calculations for the levitating wire's magnetic field.
g.gnunu
how do i find the field direction and magnitude of a horizontal copper wire with a current moving East. length is 1.0m, diameter is .10cm, current is 50 A. the wire is being levitated.
Use F=ILXB=mg.
field direction and magntiude
could you polease expand on the formula. what numbers do i plug in for mg?
m - mass of the wire
g - 9.81N/Kg. The force which a 1Kg mass exerts due to gravity.
The important thing isn't knowing which numbers to plug in where, it's understanding the principles behind the equation and where the equation comes from. Do you understand where the equation comes from?
how do i set up the formula to get the answer?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
