Field due to charge on surface of dielectric
weichi
We have an infinite half-space filled with a dielectric. The other half-space is vacuum. We take a sheet of charge of density \sigma and place it on the surface of the dielectric. What are the D & E fields everywhere?
We clearly have D_1 + D_2 = \sigma. But what other equation do we have? Can we find D_1 & D_2 without knowing the properties of the dielectric?
It seems like this should be very simple, but it's tripping me up. I don't think we can claim D_1 = D_2, because we don't have symmetry. Or am I wrong about this?
Since no one has responded yet, I will give the reasoning I've come up with for the case of a linear dielectric. We know that the effect of the polarization will be to introduce a bound surface charge density on the surface of the dielectric. Instead of working with the D field and the free charge, we can work with the E field and the total (free plus bound) charge. If we do that, we will find we have a total charge density at the surface of (\sigma - \sigma_b) and the E-field will be the same on either side.
We can then go back to D_1 + D_2 = \eps_0 E_1 + \eps E_2 = E(\eps_0 + \eps) = \sigma and we get E = \frac{\sigma}{\eps_0 + \eps} on both sides (opposite directions of course).
This has the right limiting value of E=0 on each side in the case where we take the case of a conductor and let \eps -> \infty.
This tells me that to find the values of the D field in this case you need to know something about the properties of the dielectric.
It wasn't actually a homework question, but I agree that it sounds like it could be one :smile:
you do understand that the only effect of the polarization of the dielectric will be to lessen the strength of the electric field within the dielectric itself? right? just calculate what it would be if there was no polarization then multiply/divide by the appropriate number.
So I think you are saying that we can assume that the D field is the same on each side. But that would imply that the E field outside the dielectric would be a constant independent of the dielectric constant. And I don't think that's right, because in the limit of a very large dielectric constant (which I think is equivalent to being a conductor in the electrostatic case) the field should be zero everywhere, right?
its not clear to me what would happen.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
